 Hyundai-Forums.com > Hyundai Models > Sonata Forum > 4G (2006+) Sonata > Break Pad Replacement
kali76
post May 4 2008, 01:13 AM
Drives: 2006 Hyundai Sonata GLS 3.3
Status: OFFLINE
Hi, guys.
I replaced front brakepads (Satisfied Pro Ceramic, Model: PR924-C) today; however, realized that the width of pads are little smaller than the OEM so they do not cover the inner surface of rotor completely. I have tested the braking about 20mi and seems fine, but I am concerned that using pads not perfectly covering the surface of rotor might cause the problems later.
I am driving 2006 Sonata GLS V6 (Production date: 10/31/2005) and here is the pads info:
http://www.partsamerica.com/ProductDetail....ype=219&PTSet=A
Did I install the right pad? The pad description said it's for 2006 Sonata V6. I wonder how other aftermarket pads are covering the surface of rotor? Any suggestion is appreciated.
This post has been edited by kali76: May 5 2008, 05:00 PM
User is offlineProfile CardPM
QuoteReply
mramella
post May 4 2008, 06:24 AM
Status: OFFLINE
Out of curiosity, was it difficult to replace the brake pads yourself? I'm thinking about doing the work myself, as well... Also, how many miles do you have on your '06? I also have an '06 and I'm trying to determine if it's time to replace mine. Looks like mine are pretty well worn down. I have 33k on my Sonata. I bought it used about 3 weeks ago... Thanks!
QuoteReply
ddix1026
post May 4 2008, 07:15 AM
Lonely Commuter
Status: OFFLINE
those look like the right pad.. the part number is 924, which is the same "part number" that everywhere else says is the right ones... i bought some Raybestos ATC 924's for my car as well (havent put them on yet)..
should be fine methinks :thumbsup:
QuoteReply
bobad
post May 4 2008, 07:51 AM
Fagedaboudit!
Drives: 06 Sonata GLS V6 born on 2006-01-29
Status: OFFLINE
I've seen stock pads that the swept area doesn't quite cover the entire rotor. It leaves a ridge on the outer diameter of the rotor, but it's usually harmless. If you go to a larger pad later on, you may have some issues. If the ridges are not real high and wide, they will cut themselves a harmless groove in the pad after a few gentle stops. Otherwise, you may need to touch up the rotors to prevent noise and rotor warpage.
QuoteReply
Sort Em
post May 4 2008, 08:03 AM
Drives: 2009 Hyundai Sonata GLS manual
Status: OFFLINE
I have to agree with bobad, There is normally no performance issues with a smaller fitting pad. The only disadvantage is that the rotors will need to be replaced if they wear a deep ridge in them.
I'm kida shocked they don't cover the entire surface, wouldn't the breaking power be better if there was more surface covered?
QuoteReply
ddix1026
post May 4 2008, 08:04 AM
Lonely Commuter
Status: OFFLINE
one would think.. basic physics
QuoteReply
Sort Em
Status: OFFLINE
Hey bobad, how do I get my picture to show up on the top left corner of my posting.
:offtopic:
Sorry about the off topic. I just can't figure it out.
QuoteReply
ddix1026
post May 4 2008, 08:12 AM
Lonely Commuter
Status: OFFLINE
QUOTE(Sort Em @ May 4 2008, 09:04 AM)
:offtopic:
up at the top, click on "My Controls".. once that comes up, look on the left hand side and click on "Edit Avatar Settings".....
QuoteReply
Sort Em
post May 4 2008, 08:16 AM
Status: OFFLINE
Thank you, thank you, thank you.
QuoteReply
Tommer
post May 4 2008, 10:14 AM
Drives: '06 S'nota V6 GLS (Goes Like Snot!)
Status: ONLINE
Your picture had no silicone in it!!!!! :innocent:
User is online!Profile CardPM
QuoteReply
kali76
post May 4 2008, 04:26 PM
Post #11
Status: OFFLINE
Does anyone know a ceramic pad that covers the entire swept area of rotor? I really hate to replace rotors because of deep ridge developed after using smaller pads.
This post has been edited by kali76: May 4 2008, 04:34 PM
QuoteReply
kali76
Post #12
Status: OFFLINE
QUOTE(mramella @ May 4 2008, 03:24 AM)
Actually I had a local shop replaced the pads. I was watching the replacement procedure, and it looked fairly easy with proper tools. My one had about 34.7K and the pad was about 1/8" thick.
QuoteReply
ReBeL_BLaK
post May 5 2008, 04:45 PM
Post #13
Drives: 2006 Hyundai Sonata 2.4 DOHC
Status: OFFLINE
:offtopic: BRAKES not BREAKS!! ... it was driving me crazy seeing that over and over
QuoteReply
mamamia
post May 6 2008, 02:17 PM
Post #14
Drives: 2006 Arctic White Sonata GLS 2.4 (DOB 11.7.05, on my BD!)
Status: OFFLINE
You are Write, ReBeL_BLaK.
Wait, it's now more popular to spell it Wright. :thumbsup:
QuoteReply
dogstar
post May 6 2008, 02:33 PM
Post #15
Audio geek
Group Icon
Group Icon
Group: Super Mod
Drives: 2006 Sonata GL V6
Status: OFFLINE
QUOTE(bobad @ May 4 2008, 05:51 AM)
Rotors should be machined when replacing pads, to ensure that there is a flat, level surface for the new pads to grip into.
Also, having the machining grooves will help break the brake pad in. Pun, what pun? :whistling:
QuoteReply
> Link To Us
> Similar Threads
Dome Light Replacement...
Forum : 3G (2006+) Accent
Unfated 336 17 Oct 8 2008, 07:48 AM
By: bloodninja
Front Passenger Wheel Bearing Replacement
Forum : 2G (1996-2000) Elantra & Lantra
protegechris 45 1 Oct 7 2008, 11:45 AM
By: montego
Oem Battery Replacement
dbarocio1001 84 2 Oct 6 2008, 07:20 AM
By: Spawn
Part Replacement
Forum : Grandeur & XG Forum
louisjk 59 0 Oct 4 2008, 04:21 PM
By: louisjk
Source For Replacement Body Parts
Forum : 3G (2001-2006) Elantra
MS Fowler 242 3 Oct 1 2008, 06:29 PM
By: bhurlin
11th October 2008 - 09:10 PM
