How To Replace Air Filter |
May 1 2008, 08:30 PM
Status:
Drives: '07 Sonata 2.4L / 5 speed Manual / Pearl White
QUOTE(wjc77 @ May 1 2008, 09:06 AM) hey guys.... need some tips... how do you replace air filter.. there is 3 clips thats holding the box....once i unclip that...i can see the air filter inside but..it won't lift up...do i need to unscrew some bolts and lift up? anyone have done replacing air filter? [right][snapback]157906[/snapback][/right]
Easy to replace the air filter. But there are FOUR clips. ^^^^^^^^^^^^^^^^^ > Unlatch three easy clips (see pic). > Unlatch "hidden" clip rear left (see pic). > Pull top of air box up and toward center of engine. Note: you can loosen (not remove) the air duct screw to allow the air box top to rotate a bit - don't remove the air duct! > Pull the front of the filter up and forward. Install new filter in reverse order. Regards, GEWB
May 3 2008, 08:29 AM
Status:
QUOTE(mamamia @ May 2 2008, 11:38 PM) So I guess this air filter MUST be purchased at the dealership, right?
And, as Borat used to ask:
How much? [right][snapback]158368[/snapback][/right]
Hmm, the OE and the after market were rectangular not trapezoidal. I get after market filters at Checker Auto - Fram CA10083, $14 or Purolator A35601, $15. Regards, GEWB
May 3 2008, 06:09 PM
Status:
QUOTE(kn5owa @ May 3 2008, 01:23 PM) The V6 filter is trapezoidal - I just replaced two of them [right][snapback]158469[/snapback][/right]
My bad- I only have the 4-banger. Regards, GEWB
