Dear samuel,
I have been helping Roger Holdorf in Norway with his 1.6 liter Alpha engine, which is what comes in a Norwegian Tiburon. So he wants more from his Tiburon.
Several things you can do for cheaper than a turbo in priority:
1) Port & polish the intake manifold 2) Headers 3) Crower cam regrind to 270 degrees duration 4) Raise the compression with a thin copper gasket 5) Cylinder head work-port polish the intake ports, polish the exhaust, multi-angle valve seat grind, back cut/deshroud the valves 6) Change to an Elantra 2.0 liter throttle body 7) Change to Elantra 2.0 liter fuel injectors 8) Add an adjustable fuel pressure regulator and set to 50 psi. 9) Reprogram your ECU
Then, you can think about NOx.
Byron
