Hello, I used my Yakima SkyBox 16 several times this winter. Several sets of skis, boots, etc. and it attached directly to the Veracruz. I sought guidance on weight limitations, but the dealership said that based on the specs for the SkyBox, it would be just fine. The 16 does run a bit long. It pushes on the antenna in the back, but the XM still works fine eventhough its partially covered. A shorter box would probably be perfect. But to answer your question, the box attaches without a problem to the factory rails. Higgo
