QUOTE(mohdc @ Apr 28 2008, 10:23 PM)
I had a similar situation, and ended up replacing sway bar link on the right and left front of my accent. Not too bad job. Make sure to use penerating oil on the good side if you are planning to replace it as well. The link kit is cheap too. I had to remove the whole sway bar as I was replacing the steering rack due to seal leak.
Have fun.
Hi Newbi,
The only thing I could add to your comments here would be that I had the same issue and used a saws all to remove mine. Worked nicely.
I went to NAPA for mine as it is close and they offer the two styles, one is a rubber replacement and the other is Polyurethane, the poly is preferable as they won't break down over time as rubber will. You will also notice zero difference in ride quality with the plastic bushings, the stabilizer will also be able to do its job slightly better.
Gerald
