 Hyundai-Forums.com > Hyundai Models > i30 Forum
> I30 Tow Bar, A coupla complaints...
dazzling_darryl
post Apr 22 2008, 06:25 AM
Drives: 2008 Hyundai i30 CRDi SLX Manual & 2007 Nissan Tiida Manual Sedan (Wifes car)
Hello anyone with a towbar on their i30 (bob and ???)
My new towbar came with a neat plastic cover over the"slot" where you poke the tongue in. They just put the tongue with Towball attached in the boot and a couple of chain clasps in my console.
When I put the tongue in the slot two things happened:-
Firstly, when I pushed the pin up from underneath it came up against the base of the plastic bumper so I had to put real pressure under it so I could do the bright orange nut up tightly before putting the locking pin in place.
The when it was tight I could still wobble it slightly side to side. Noisy and would have been noticeable while driving. (major technical fix here, have pens to the ready... I jambed the clip part of a black pen cap in the gap (worked rather nicely but shouldn't have been required)
Then...later noticed a new sticker in my drivers door jamb with towing weights etc... and it says quote "for towing of trailers only" ...lucky I didn't buy that little caravan to put on my new block for amenities use!!!!
Never had a towbar before (except on my Company vehicles) but assumed all towbars were made equal???
Thats it for now (photos to come)
Rgds,
Dazz
dazzling_darryl
post Apr 22 2008, 07:22 AM
Some photos I prepared earlier (just used my mobile so they aren't that clear)
Can't see the technical adjustment made with pen clip but can hopefully make out bow in plastic bumper caused by pressure of bolt coming up from underneath.
Attached File(s)
tjaliwalpa
post Apr 22 2008, 07:41 AM
Drives: 08 i30 CRDi 1.6 Manual / 09 Santa Fe CRDi 2.2 Auto
Dazz,
Don't think I have the problem of the pressure up against the bumper, but I will check later in the week (I'm away for 2 days so won't be posting - don't all cheer).
A caravan, by the way, is a trailer. However, there are only a limited number of caravans with a ball weight less than or equal to 75kg. Have come across a range of vans manufactured in Geelong that would be suitable. They are designed to be towed behing front wheel drive cars and the smallest can even be towed by a Getz or a Yaris. http://www.driftaway.com.au/lrmini.htm
Also, I have turned the connector upside down so that it is mounted on top of the metal plate. I thought it was being asked to be ripped off mounted underneath the metal plate.
Bob
dazzling_darryl
post Apr 22 2008, 07:44 AM
Thanks Bob,
As usual worthwhile tips.. No wonder your infamous (i mean famous) in your part of the country... :clap:
Rgds,
Dazz
tjaliwalpa
post Apr 25 2008, 12:18 AM
Dazz,
and others with towbars
plus those interested in towbars
(Everyone I guess),
Had a closer look at the towbar and tongue. I can see what you mean about the tongue being loose in the slot that it fits in. It is no more of an issue than it is with the square tubing type fitted to larger vehicles. In these cases I have always made up a spacer out of thin plastic (an icream lid is ideal material) . I tried it out on the i30 and it works a treat. See the pics below.
Also see what you mean about the tapered pin pressing up against the bumper, although ours doesn't quite touche. See pic below.
Have included a number of pics to give others a good idea of how the bumper and attachments look.
Notice also that I have put the socket on the top of the supplied plate. I have had sockets ripped off on previous vehicles when they are fitted underneath.
Bob
This post has been edited by tjaliwalpa: Apr 25 2008, 12:21 AM
Attached File(s)
dazzling_darryl
post Apr 25 2008, 05:17 AM
Hi Bob,
Nice clear pix.. did mine with my phone - being lazy. My tongue is loose side to side more than up and down. That's probably why I say offensive things on the forum...well not really (that's why a pen top worked ok for me.)
It appears my towbar may have been installed very slightly inboard than yours hence the fouling of the pin with my plastic bumper (not worth complaining though)
Regards,
Dazz
Is tjaliwalpa an aboriginal word, a combination of your families initials or did you just bump the keyboard once and decided you liked the look of the result :innocent:
This post has been edited by dazzling_darryl: Apr 25 2008, 05:20 AM
Seoul-mate
post Apr 25 2008, 05:25 AM
Drives: i30 SLX 1.6L Diesel 5 spd manual
Hi Dazz,
my towbar is exactly as you describe yours. ie. when the bolt is put through and tightened up with the big red plastic nut it touches the bottom section of the plastic rear bumper and causes it to flex just a little. And the tounge is relatively loose when fixed into position.
My previous car ( VZ Calais) had a Hayman Reece towbar...the removable square tube type that is also held in place by a pin and clip. It was loose when put into position but to fix it into place a threaded hole had been tapped into the side of the outer tube so that a hexagon bolt could be tightened up against the tongue inside, fixing it tightly and stopping any movement. Now I am thinking of going to an engineering place and getting the same thing done to the i30 bar. I think there would be room on either side of the outer tube to tap a threaded hole through.
I'll let you know how I get on once I get around to doing it.
Russ
P.S. My flat pin connector was already attached to the top of the metal plate by the installer, just as Bob suggested he had done.
dazzling_darryl
post Apr 25 2008, 05:54 AM
Thanks S-M,
Being a cheapskate, I might just put a colorbond Tek Screw (e.g. Self Drilling screw) in either side if my plastic pen clip (aka highly technical fix) doesn't do the job. Your idea is obviously the more professional approach...
Will move the connector to top of the plate as soon as I get a chance as that wont cost me anything.
Cheers,
Dazz
tjaliwalpa
post Apr 25 2008, 07:42 AM
Dazz,
If yours is loose sideways, you could find suitable plastic strips to fit either side of the tongue.
Bob
dazzling_darryl
post Apr 25 2008, 08:21 AM
Hi Bob,
Will give it a try but even though it will swing slightly either way enough to rattle, doubt I would be able to put even the thickness of an ice cream container plastic in the gap..
Rgds,
Dazz
turbo1600
post Apr 25 2008, 09:49 AM
Post #11
Drives: 95 Excel Sprint 2DR Hatch 1.5 SOHC M5, 08 i30 SX CRDi M5
How much weight can you tow with an i30 out of curiosity?
I think I might go with a Hayman Reece kit instead of the Hyundai kit, doesnt look that great.
dazzling_darryl
post Apr 25 2008, 04:42 PM
Post #12
Hi Turbo,
It's on the Hyundai site (and in the book) but from memory it's 500Kg unbraked and 1200kg braked...Although as Bob has stated can only handle a direct towball weight of up to 75kg.
Cheers,
Dazz
tjaliwalpa
post Apr 25 2008, 06:41 PM
Post #13
turbo1600,
As far as I can ascertain, Haymen Reece do not yet make a bar for the i30. Found one on a WA site that was made for an i30, but there were no details other than a limit of 1200kg (same as Hyundai bar).
http://www.parksidetowbars.com.au/specials.html
All in all, as I have said before, it is well designed and a neat fit. I believe it is the fitter who has stuffed up in some cases by making the cut out of the bumper a little smaler than it should be. Regarding the loose fitting of the tongue in the slot, you will find that this is the case with most slip in type tongues, even the Hyamen Reece. Not all Hyamen Reece bars have the grub screw.
Bob
mightyteal
post Feb 13 2009, 01:14 PM
Post #14
Drives: 2007 i30
I got the Parkside towbar on the i30 supplied and fitted by MATADOR Tow Bars in Sydney for $350. Have had it for 9 months now and its been fantastic - no looseness and handles a 4 bike rack no problems.
i30man
post Feb 16 2009, 04:20 PM
Post #15
Drives: 2008 SLX i30 Diesel
Hey all
I don't have the problem with mine at all but the funny thing is my factory fitted towabar is straight it doesn't curve up like all the others in the pics.
(IMG:http://www.hyundai-forums.com/uploads/post-41950-1209100412_thumb.jpg)
Its not like the one above i can attach some pics for you all if your inetrested?
Cheers Nick
itza
post Feb 17 2009, 01:13 PM
Post #16
Expert
Dazz
Have a look in the Tucson forum as nomad had a problen and whatever bar he used has been pulled and has altered the sub frame and Hyundai now saying it cannot be fixed under warranty.
The tow bars you guys seem to be using seem to me to leave a lot to be desired. In the UK weve been using Witter and Bosal and they seem to be more up to the job.
Reference your tow bar touching your bumper - IT SHOULDN'T - the Tucson for instance has to have a small peice cut out the underside (really a small bit) that stops the bumper touching and possibly buckling when under tow - don't forget that as you cover bumpy roads there will be a bit of movement.
Towing weights- the Caravan Clubs and others recommend that the total weight towed does not exceed 86% of the authorised capacity and this is considered to be a safety zone.
Hyundai by the way only have an authorised 75kg down weight on all of their vehicles except the biggest 4x4 where it does increase slightly.
I have put a link into witters on the tucson page- by the way my tow ball is bolted onto my bar with two really chunky bolts.
Photo of my 5/6 berth Avondale and Tucson attached and I believe that when you double click the picture the size will increase and you will just be able to see the back end of my tow hitch on the Tucson. We also use Alko hitches on the caravans as these are manufactured to ensire that when the units are coupled they reduce the swaying action and assist in maintaining a safe tow.
Cheers
Itza
i30cwWhite
post Apr 8 2009, 08:44 PM
Post #17
Drives: 2009 Hyundai i30cw 1.6 CRDi Auto
QUOTE (tjaliwalpa @ Apr 25 2008, 02:48 PM) *
Dazz,
(Everyone I guess),
Bob
I have just collected my new i30cw SLX 1.6L CRDi Auto yesterday.
I like it and my boys are very impressed with its looks and its internal features.
Please tell me where can I get this towbar with detachable tongue in Adelaide, SA?
This post has been edited by i30cwWhite: Apr 8 2009, 08:50 PM
Shambles
post Apr 9 2009, 02:03 AM
Post #18
Status: Online
Drives: 2008 i30 1.6 CRDi Premium
QUOTE (i30cwWhite @ Apr 9 2009, 01:44 AM) *
Hi there.
Most of the contributors in this thread now reside in the i30 owners club. Click the link in my sig to access that forum, where I'm sure you receive an instant response (IMG:style_emoticons/default/smile.gif)
Regards
marty62
post Nov 10 2009, 05:25 AM
Post #19
Drives: 2008 I30 1.6 CRDI
I have an after market towbar attached, my question to those that have an Hyundai fitted bar is, do they retain the plastic undertray or is it removed as is the case with the after market bar.
Cheers
No New Posts I30 Alloys
0 rdz4 81 11th November 2009 - 09:50 AM
Last post by: rdz4
No New Posts I30 Delivery
1 ghosty123 198 1st November 2009 - 06:07 PM
Last post by: ayrshiretiger
No New Posts I30 Delivery Times
7 bizzay1 599 17th October 2009 - 02:48 AM
Last post by: philipsw
No New Posts I30 Es
2 andylane1919 430 12th October 2009 - 02:00 PM
Last post by: bulldog180
No New Posts I30es Delivery Date
2 jayeshkumar 284 12th October 2009 - 01:43 PM
21st November 2009 - 02:19 PM
Privacy Statement
