I wonder if this is the same for all Tuscanis, but I've noticed something about the windows. After the rain, when rainwater is on the windows, I normally wind down then wind up the windows to clear the rainwater. However when I did this, the water still remained on the window. So I have to wipe the windows dry before moving off. Grrr ... Is there any way to go around this?
Furthermore, this meant that instead of water sliding down from the side of the doors, it went into/through the door, doesn't it? This doesn't sound good to me. Does the mechanism inside the door get affected by the rain water?
Do you have the same problem and what do you guys think?
