 Hyundai-Forums.com > Hyundai Models > Santa Fe Forum > 1G (2001-2006) Santa Fe > A'c Keeps Coming On
 A'c Keeps Coming On
rossy
post Apr 19 2008, 06:46 AM
Drives: Santa fe 2001
Status: OFFLINE
Hi i am new to the forum
got my self a lovley Santa fe 2001 2.7 V6 24v DOHC Auto
i love it to bits
i have a question all of the controls in the car are strait forward
but can anyone please tell me why my Air con comes on every time i start the car?
or point the blowers to the Windscreen? or is that a function its suppsod to do?
many thanks
Rossy
User is offlineProfile CardPM
QuoteReply
steff_1965
post Apr 20 2008, 11:44 AM
Drives: Hyundai Santa Fe GSI
Status: OFFLINE
Hi again rossy,
If it is the dial type like mine below then the AC comes on as soon as the windscreen position is selected. It drives me nuts as i never use the AC.
(IMG:http://img.photobucket.com/albums/v124/Steff_1965/Dash.jpg)
QuoteReply
rossy
post Apr 20 2008, 11:48 AM
Status: OFFLINE
Oh well thanks for that bud
one other thing you could help me on
is the 4x4 opion switchable? or is it constant 4x4 motion
many thanks
QuoteReply
steff_1965
post Apr 20 2008, 11:52 AM
Status: OFFLINE
I am not a technical person but as far as i know the car drives front wheel drive until it slips then it changes itself to four wheel drive.
I am sure someone will explain it better for you soon.
QuoteReply
NovaResource
post Apr 21 2008, 09:01 AM
Drives: Nautical Blue 2006 Tucson 2.7L V6
Status: OFFLINE
The A/C is designed to come on when the windshield defog position is selected. The A/C helps dry the air and remove humidity from the interior which clears the windshield quicker. You want the A/C on when clearing the windshield.
QuoteReply
SongDog
post Apr 23 2008, 10:44 AM
Drives: 2001 Hyundai Santa Fe GLS 2.7
Status: OFFLINE
I have to say this was one of the dumbest design decisions on this vehicle. The last thing you need when trying to crank in cold weather is to have the A/C compressor loading the engine down. I sure hope they've change it by now.
QuoteReply
NovaResource
post Apr 23 2008, 10:50 AM
Status: OFFLINE
QUOTE(SongDog @ Apr 23 2008, 11:44 AM)
The A/C compressor is disengaged when starting (and when the throttle is wide open). You are not turning the compressor when cranking in cold weather. Even notice how the radio is turned off when cranking? It's the same for the A/C.
This post has been edited by NovaResource: Apr 23 2008, 10:51 AM
QuoteReply
rossy
post Apr 23 2008, 10:59 AM
Status: OFFLINE
is there maybe a wire some were we can cut to stop this?
QuoteReply
NovaResource
post Apr 23 2008, 11:17 AM
Status: OFFLINE
Why would you want to? Having the A/C on gets rid of the humidity in the cabin and clears fog from the windshield quicker.
QuoteReply
steff_1965
post Apr 25 2008, 12:55 AM
Status: OFFLINE
I have never been a fan of AC and never used it on any of the cars i have had. The Santy is the first thhat i have had that works and i hate it. lol. If anyone does know of a way of getting it permanently off then i would also like to know as well.
QuoteReply
NovaResource
post Apr 25 2008, 07:27 AM
Post #11
Status: OFFLINE
Again I'll ask, why? What about it do you hate? Have you tried using it to clear the windshield?
If you really want it off just pull the A/C fuse in the fuse box or disconnect the wire connector on the compressor clutch.
(IMG:http://www.hmaservice.com/data/Passenger/HY/HMA/ENG/SHOP-Images/HY-SM13-IMAGES-ENG/eqjd115a.gif)
(IMG:http://www.hmaservice.com/data/Passenger/HY/HMA/ENG/SHOP-Images/HY-SM13-IMAGES-ENG/eqjd115b.gif)
This post has been edited by NovaResource: Apr 25 2008, 07:28 AM
QuoteReply
lovemysantafe
post Apr 27 2008, 10:27 PM
Post #12
Drives: 2004 Hyundai Santa Fe (SM) GLS 4WD (DOB 5/24/04)
Status: OFFLINE
I must agree...why do you want to disable this feature? I had a car where the A/C did not turn on with the defroster setting and it took a good 2 to 3 minutes to clear the windshield. They didn't do this for their own amusement... :whistling:
QuoteReply
Ynot4me2
post May 2 2008, 10:59 AM
Post #13
Drives: 2005 Santa Fe 2.7 FWD
Status: OFFLINE
I also agree... why would you. When defrosting the windshield in the cold weather, if you have the temperature dial on hot all it's doing is removing the humidty. It's not pushing cold air. By removing the humidity, your window will defrost a lot quicker.
QuoteReply
steff_1965
post May 4 2008, 11:51 AM
Post #14
Status: OFFLINE
I don't use any heater functions when the windscreen is frosty. Before i start the engine I pour warm water over the windscreen to melt the frost then get in and start the engine then drive away. No AC and no misting up on the inside. So no need to have AC coming on when the heater dial is set to windscreen/floor position. :)
This post has been edited by steff_1965: May 4 2008, 11:52 AM
QuoteReply
NovaResource
post May 5 2008, 08:58 AM
Post #15
Status: OFFLINE
QUOTE(steff_1965 @ May 4 2008, 12:51 PM)
That's a great way to crack the windshield.
You do know that you have windshield washer fluid that melts ice? It amazes me that people don't want to use the options/tools in the car to do a job.
This post has been edited by NovaResource: May 5 2008, 09:01 AM
QuoteReply
steff_1965
post May 5 2008, 11:02 AM
Post #16
Status: OFFLINE
QUOTE
Ive been doing that for years and never had a windscreen crack.
QuoteReply
NovaResource
post May 5 2008, 11:50 AM
Post #17
Status: OFFLINE
Just because you haven't yet doesn't mean it's the correct way.
Bottom line: pouring warm water on a frozen windshield is a bad idea. If it worked for you great but I don't advise anyone else doing it.
This post has been edited by NovaResource: May 5 2008, 11:51 AM
QuoteReply
wilspin
post May 9 2008, 09:15 PM
Post #18
Drives: 2006 Santa fe 2.7
Status: OFFLINE
Novaresource is quite correct. All cars have been this way for 30 years now.
This post has been edited by wilspin: May 9 2008, 09:17 PM
QuoteReply
steff_1965
post May 10 2008, 12:37 AM
Post #19
Status: OFFLINE
QUOTE(NovaResource @ May 5 2008, 05:50 PM)
Years ago windscreens would apparently shatter if warm water was poured over them but nowadays there are fine providing the water isn't too warm. I am not saying its the correct way but it has worked for me for about 10 years now on all my motors/vans without any problems.
QuoteReply
NovaResource
post May 12 2008, 09:22 AM
Post #20
Status: OFFLINE
QUOTE(steff_1965 @ May 10 2008, 01:37 AM)
Again, if it works for YOU, fine. But don't advise other to do it. It is bad advice.
QuoteReply
> Link To Us
> Similar Threads
Vibration Coming From Rear
tapemonkey 157 4 May 29 2008, 03:11 PM
By: tapemonkey
Genesis Targa Coming Soon?
Forum : Genesis Coupe
yanyo 325 2 May 12 2008, 02:35 PM
By: Valk
Auxillary Audio Input Coming Next Month!
Forum : Veracruz Forum
kevio 1,384 9 May 10 2008, 08:12 AM
By: nykerk
Strange Noise Coming From Vents
Forum : 2G (2000-2005) Accent
crhayes31288 210 2 Mar 17 2008, 07:16 AM
By: toddy95
Battery Warning Light Coming On With Bad Smell
Forum : 1G-3G (1989-2005) Sonata
dutta7sk 171 1 Mar 8 2008, 06:21 AM
By: byronguidry3732
3rd July 2008 - 06:00 PM
