2 Pages V   1 2 >
> Door/seatbelt Chime..., has anybody located the speaker?
devin6687
post Apr 15 2008, 04:38 PM
Drives: 2006 Hyundai Sonata LX V6
It's annoying me and I really want to do something about it. I think I remember reading somewhere that a guy put some cotton around it to quiet it down a bit (I can no longer find that post), but I want to disconnect it or at least put a resistor on it to quiet it down.
Has anybody found it, and if so, could you post pictures showing how to get to it? I want to find it, but I don't want to rip my car apart to get to it, so if somebody else has already found it, I'd love to hear from you.
I've heard about the solution for jamming the driver seatbelt sensor, but that still doesn't fix the door chime and I don't want to jam all the sensors.
Dennis the Menni...
post Apr 15 2008, 05:05 PM
Expert
Drives: "KC" 06 GLS 3.3L DOB 2-16-06 Bright Silver Metallic
You have to remove the center console to get at the module with the chime. I think that qualifies as "tearing the car apart." That's the only way to get at the chime. Once you expose it you can tape over the slotted area that the bong-bong screams at you from, but you have to get at the module first.
Dunno if you want to just quiet the li'l bugger or drive beltless. If it's the former, please ignore the following.
I think there's a way to kludge something with the seat belt buckle, but I will not discuss it. I've been a seat belt man since the day that seat belts saved Dad's life.
Toolman
post Apr 15 2008, 07:28 PM
Drives: 2006 Hyundai Sonata LX 3.3
Yes, I wear my seatbeat all the time, but this warning sound should go off when the car is in gear, not the second the key is turned on. That being said, there is an easy way to stop this sound without taking the car apart. First you need about 10 minutes and a #10 security torks bit. The bit is not something you can find very easy, but there is a easy way around this. Pickup a #10 bit which you can find at most hardward or lumber stores. File the tip down so it is flat and drill a hole down the middle. A drill press is the best way to do this. Start slow and let the drill bit do the work. You need a hole only about 1/8" deep. Now go to the driver side seatbelt buckle and remove the two screws holding the case together. Now that it is open, buckle the seat belt and watch what it does. You should see a small plastic piece (red in color if I remember) with a little copper plate on it. As the buckle goes in it moves a contact from the copper piece to plastic . Just take a small screw drive or pick and pop that copper piece out. Before you put things back together just make sure your buckle clicks in like it did before. That plastic piece needs to be there for the buckle to work.
This only effects the seatbelt warning all other safety and warning features work just fine.
dman1458
post Apr 15 2008, 07:38 PM
Drives: 2006 Hyundai Sonata GL 2.4, 2005 KIA Sorento LX
This is the fix.
I did it to my Sonata like 2 years ago and would not for one second go back and change it back. I enjoy all the beltless silent bliss I want (BTW I never drive without my seat belt.)
This does not effect anything so the airbags and such will all work just fine. In total the fix will take you less that 20 minutes. You might try just filing the torx down flat before drilling a hole in it. Also you might find it easier to drill the "nub" out of the screw in the seat belt latch.
Tony20
post Apr 15 2008, 09:51 PM
Drives: 2007 Sonata GLS
easy fix take 2 seconds and buckle up no ding from the chime and your safe. :thumbsup:
This post has been edited by Tony20: Apr 15 2008, 09:52 PM
craigbrooks
post Apr 15 2008, 10:18 PM
Just hangin' out...
Drives: 2006 Hyundai Sonata GLS F24S (DOB 04/30/05), 1997 Mustang V6 Convertible
QUOTE(Toolman @ Apr 15 2008, 06:28 PM)
[right][snapback]152985[/snapback][/right]
Read this post down a few by rbuet. I did this and I am chime free. :banana: Thanks brother. :thumbsup: A readily available torx bit works here just fine.
http://www.hyundai-forums.com/t21123-remov...nsor-buzzer.htm
Darn I can drive around all day without my belt on and throw caution to the wind WITHOUT that annoying noise. :w00t:
I always wear it anyway, but I can go "beltless" while waiting for the car to warm up, at the bank, etc. Best "mod" I have done to date. :clap:
This post has been edited by craigbrooks: Apr 15 2008, 10:19 PM
ddix1026
post Apr 16 2008, 07:21 AM
Lonely Commuter
annoying as f*ck chime... but it has made me put my seatbelt on again after not wearing it for years... :clap:
Southsider1
post Apr 16 2008, 07:50 AM
Drives: 2008 Hyundai Sonata GLS 4-cyl, 5-sp manual; 2004 Toyota Sienna CE; 1992 Honda Accord EX, 5-sp manual
Here are more posts to various threads. Sounds like the two solutions are 1) the previously mentioned tampering with seatbelt itself (uncertainty about whether this sensor is connected to anything important besides the chime), and 2) muffling the chime itself. The chime is located under the center armrest/console.
http://www.hyundai-forums.com/t21123-st-20...nsor-buzzer.htm
http://www.automotiveforums.com/vbulletin/...ad.php?t=548134
http://www.hyundai-forums.com/index.php?showtopic=20226&hl=
http://www.hyundai-forums.com/index.php?showtopic=17538
http://www.hyundaiperformance.com/forums/s...me-disable.html
http://www.hyundai-forums.com/index.php?sh...058#entry104058
It's a popular topic. Makes you assume that Hyundai doesn't read these posts or they would have changed it. My 2008 has the same problem.
devin6687
post Apr 16 2008, 09:54 PM
I did it. I covered it with like 10 layers of electrical tape, a piece of foam, and then put a big rag kinda thing around it. It's a lot quieter now, but it's still annoying.
craigbrooks
post Apr 16 2008, 11:16 PM
Just hangin' out...
Dude pull the plug (out of the receptacle) on this thing. Trust me you will thank yourself the next day. :beer:
ddix1026
post Apr 17 2008, 09:00 AM
Post #11
Lonely Commuter
i thought it was soldered on?
devin6687
post Apr 17 2008, 12:05 PM
Post #12
QUOTE(craigbrooks @ Apr 16 2008, 10:16 PM)
[right][snapback]153481[/snapback][/right]
but doesn't that control other things besides just the beep?
Klute
post Apr 17 2008, 01:55 PM
Post #13
Drives: 2007 Sonata Limited - DeepWater Blue
Nice chime makes sure your are buckled in, but now my hearing is starting to go...think Hyundai will cover hearing aid & batteries?
Dennis the Menni...
post Apr 17 2008, 04:31 PM
Post #14
Expert
See my post today (near the end) of the **** Peanuts! thread for a peek at my dashboard.
This post has been edited by Dennis the Mennis: Apr 17 2008, 04:33 PM
craigbrooks
post Apr 17 2008, 04:38 PM
Post #15
Just hangin' out...
QUOTE(devin6687 @ Apr 17 2008, 11:05 AM)
[right][snapback]153636[/snapback][/right]
Seatbelt chime and airbag deployment. It is my understanding the bag will deploy softer if you are buckled in. May be wrong but I am always buckled in when the car is in motion so it doesn't matter.
What matters is is that my car has no seatbelt bonger.
This post has been edited by craigbrooks: Apr 17 2008, 04:38 PM
iowason07
post Apr 17 2008, 09:18 PM
Post #16
Drives: 2007 Hyundai Sonata Limited 3.3
I just fixed my annoying chime. I removed the 2 security torx screws of the buckle (driver's side) using a jeweler's screwdriver, then removed the small sliding black piece that holds the contacts for the sensor. After taping it into the buckle for future reinstall is ever needed (like upon resale), I reinstalled the screws. No more chime when the belt is not fastened, but the chime still works for all other functions, like key in the ignition and the door open. Since I ALWAYS wear my belt, I don't need a reminder to buckle up. PLEASE PLEASE, if you need a reminder to use your seatbelts, DO NOT DO THIS!!! Seatbelts really do save lives and lessen the severity of injuries. Good luck to all, and remember BUCKLE UP AND LIVE. Happy motoring :57:
craigbrooks
post Apr 17 2008, 09:42 PM
Post #17
Just hangin' out...
QUOTE(iowason07 @ Apr 17 2008, 08:18 PM)
[right][snapback]153823[/snapback][/right]
ahhhhh good job graaasshopper. :P you learn well. :grin:
madderhatter
post Apr 18 2008, 08:24 PM
Post #18
