You don't have to take the whole console just the upper part (dark grey plastic. My only concern is that if you have the GLX 3.5L that you unplug the seat heaters before you try to lift the seat out. Removing it is just he 4 BIG bolts on the bottom, they're covered by the caps on the ends of the rails.
When you are makring the location for the amp, make sure that the rails do not interfere with them, and that you have easy access to the wires. Mine are all facing towards the front, so all i have to do is slide the seat all the way back to make any adjustments.
