> A/c Always On In Defrost Modes?
05commuter
post Feb 13 2005, 12:32 PM
Drives: 05 Accent
The A/C comes on automatically when you turn the heater control to either defrost /floor or defrost. The handbook says you can turn the a/c off if you press the a/c button. Unfortunately this does not work and the a/c remains on under these conditions and this wastes gas! If the a/c comes on automatically then I would assume the a/c button should light up and mine does not. Can anyone verify if their a/c button lights up in the defrost modes and whether the a/c does turn off when you push the a/c button. You can check this by observing the a/c compressor, it has a electro- mechanical clutch and when the a/c is off the clutch does not turn, only the pulley.
Thanks, :57:
This post has been edited by 05commuter: Feb 13 2005, 12:37 PM
duke
post Feb 13 2005, 05:15 PM
Community Advisor
Group: Community Advisor
Drives: 2007 NF Sonata 2.4L
the A/C is triggered by a little micro switch, which is operated by the "Mode selector" gear. There are 2 cam-notches, a single notch at def/floor, and a double notch at def. We cut the single notch from the little gear (made of plastic), so that the A/C only comes on in DEF. Also, you can ask the tech to disconnect the 2-pin connector for the micro switch, and the A/C will not come at all, unless you press the A/C button.
Atti_5
post Feb 14 2005, 06:26 AM
Drives: Hyundai Accent Elegance 1,3 12V SOHC 62kW, Model 2005
QUOTE
Yes, Air COndition works in my 2005 Accent as decribed by You and owner-manual. When directing air flor to window-defrost or window/legs, AC LED switches On. When I press the AC button, it goes off.
As You need to run AC once a week for 5 minutes from maintenance reasons, I found this is a good idea.
Best wishes, Attila
05commuter
post Feb 14 2005, 07:38 PM
Drives: 05 Accent
Thanks for the info! :D
yakamichi
post Feb 17 2005, 10:56 PM
Drives: hyundai accent gls
yes... that's exactly what happens in my 2000 accent gls too - and this is as per the owner's manual. reason is that you typically use these modes only with the windows up, and at that time there's every chance of condensation happening on your windscreen - to clear this up, the a/c starts.
enjoy!
31 PastorK 869 Yesterday, 08:45 PM
Last post by: PastorK
No New Posts Instrument Panel Lights
3 rcacs 34 Yesterday, 12:33 PM
Last post by: rcacs
No New Posts Topic has attachmentsAccent Vs. Deer
The deer was at a handicap...
9 blazianenigma 133 29th November 2008 - 12:58 AM
Last post by: hyunnychub
No New Posts Infinity Sound System Hiss
Has anyone found a solution yet?
17 torscotty 196 26th November 2008 - 04:39 PM
Last post by: Ken SantaFe
No New Posts Only 2 Spark Plugs In 2002-05 Sonata?
6 Bakesalee 62 26th November 2008 - 02:30 PM
Last post by: byronguidry3732
2nd December 2008 - 06:14 AM
