Hi, 2000 Elantra hatchback with factory immobiliser, transponder in key, located in Sydney/Aust.
symptom ; starts AOK, then soon as starts, dies immediately. Not even enough time to rev it, just starts and dies immediately. Key to "off" then try restart. Often will not fire, but occasionally will repeat the start-then-die-immediately scenario.
Can resolve problem with removing key from ignition, then arm and disarm the remote and try starting again - usually goes AOK.
Have new Genuine key, coded by Hyundai dealer, yet to properly "test" if symptoms persist with this new key.
My thoughts are the transponder in the old key is dead, and hence not turning off the immobiliser.
But is there any way of checking the immobiliser circuit - presumably there is some sort of "reader" near the ignition to pick up the presence of the key's transponder???
Any thoughts on the functioning of the immob system, or even other thoughts on likely culprits are greatly appreciated.
Cheers, David B.
