Effects Of Broken Balance Belt |
Apr 16 2008, 11:57 PM
Group: Super Mod
Status:
Drives: 2009 Kia Sorrento 3.3, 2008 Sonata 2.4, 2003 Tiburon GT 2.7, 2004 Santa FE FWD 2.7
Dear kit,
The balance belt normally does take out the crank sensor when it breaks. You will do no long term damage from a few hundred miles of operation with a broken balance shaft belt, but the engine will vibrate heavily. Once you replace the inner belt and the crank sensor, your engine should run fine.
did your mechanic advise to replace the timing belt but not the inner belt? This is penny wise and pound foolish. the inner belt is only $15.
The alignment of the balance shaft requires locating the flat side on the shaft and blocking this in that position with a long bladed flat screwdriver through the alignment hole in the back of the engine block.
Byron
Jun 4 2008, 06:02 PM
Group: Super Mod
Status:
Dear kit,
To confirm a bent valve, your mechanic can do a cylinder leakdown test. For this test, the mechanic rotates the engine so the suspect cylinder is intake valves closed and exhaust valves closed, pumps 100 psi in the sparkplug hole with a special coupler, and watches the pressure guage for 5 minutes. If the pressure drops immediately, you have a burnt valve or bent valve stem preventing a proper seal.
If the engine runs faster than ever, great. Normally a bent valve or burnt valve does not make your engine run faster.
Since you describe this noise as a ticking, and considering how many other things 'froze' up, you may have a sticking hydraulic lash adjuster. You can confirm this with a long bladed screwdriver, touching the suspect area of the valve cover, and placing your ear against the screwdriver handle. Sure enough, if the ticking is loud and distinct at the valve cover, your noise is outside and above the cylinder head. you could try something like Marvel Mystery Oil to break loose this sticking hydraulic lash adjuster.
Byron
Nov 3 2009, 07:25 PM
Status:
Drives: 01 Hyundai Sonata
Did you ever identify the tick? I have it also.. coming from the passenger side of the motor. Bought the car it had been sitting for god knows how long (01 sonata 2.4) I replaced the trans, the power steering was squeeling, replaced that. But still got this annoying ticking. Checked the lifters with a feeler guage, no problems there
Similar Topics
Similar Topics
