> Check Engine And Abs/esc
hmr1979
post Apr 11 2008, 09:10 PM
Drives: 2006 Hyundai Sonata 3.3L V6
So I am sure there has been tons of threads about this. I am at 37 K, check engine light came on this week. Will take it to the dealer tomorrow. ABS/ESC has been coming on and off sporadically but I think I will tell him about it too.
Anything I can expect from this before I take it to the dealer?
craigbrooks
post Apr 11 2008, 10:37 PM
Just hangin' out...
Drives: 2006 Hyundai Sonata GLS F24S (DOB 04/30/05), 1997 Mustang V6 Convertible
Free oil change? :trophy:
I'd definetly tell them about the ESC/ABS lite coming on. Why hold back? Unless they come on when you are using the safety feature. :whistling: They need all the info they can to help solve your problem.
hmr1979
post Apr 12 2008, 09:23 AM
I told them about the abs/esc when it first started coming on. Because it does not stay on, they said they cannot do anything about it. no light, no code. But I will tell them again about it when I turn the car because of the check engine light.
californiadude99
post Apr 12 2008, 09:38 AM
Drives: 2006 Hyundai Sonata LX 3.3L V6
QUOTE(hmr1979 @ Apr 12 2008, 07:23 AM)
[right][snapback]151609[/snapback][/right]
I would opine that if you have an AutoZone in your area, use their loan-a-tool service and check out the engine code. That way you could be a little more specific to the dealer, but methinks maybe it has to do the the Traction Control?? :whistling:
dcjwlee
post Apr 12 2008, 01:39 PM
Expert
Last night, second time this has happened, both times on the same offramp.
It must be cursed, when I got back on the gas halfway through the turn there was no response from the engine followed by sudden downshift and high revs.
ESC OFF light + CEL light turns on, gone a few hours later both times.
IDK about the first time, but yesterday I was running on about 3 gallons of fuel and it is a steep uphill sweeper with the road sloping down to the right. The CEL went away after I filled up the tank.
Is it possible that there was no gas getting to the engine at that angle? Since it was uphill, sloping to the right, and considering i was getting on the gas that would shift mroe weight backwards... Empty light was not on at this point.
dwnthehatch
post Apr 22 2008, 06:35 PM
Drives: 2008 Santa Fe SE
I had my v6 sonata in twice for this problem. The first time they found a code C1503 and they reset the computer. The second time they got a code C1513 (Brake light switch sticking) and replaced the switch. Everything has been fine for a year now.
tfike110
post Aug 8 2008, 10:15 PM
Drives: 06 Sonata V6
Same thing just happened to me today. Got in the car and the check engine light was on and did not go off. The ABS and ESC lights have been coming and going, but a lot more frequently lately. So off to the dealer tomorrow to get everything straightened out. I know many have experienced the ABS/ESC probs, but this is the first time the MIL has appeared too. Hopefully this is the last time.
tfike110
post Aug 13 2008, 08:50 AM
Brought it in and they said it was the brake switch that set off the ABS, ESC Off, and Check engine light.
I thought it might be something different b/c others didnt have the MIL come on too.
ruthlessromeo
post Aug 13 2008, 08:54 AM
Drives: 2006 Hyundai Sonata v6
my check engine light was on, I topped off all the fluids. I have not seen it since. Have not see the other lights though.
szwakon
post Aug 17 2008, 08:21 PM
Drives: 2006 Hyundai Sonata V6 GLS, 2008 Mazda5 GT
It may be a faulty throttle position sensor as well. Some 06 and 07 Sonatas have this problem (there was a tech bulletin about that as far as I remember). Mine did the same thing twice (it happened when I was merging on the highway with fairly cold engine at full throttle, the engine jumped to limp mode, and esc/abs light came on). My dealer replaced the sensor and the problem went away.
dwnthehatch
post Aug 17 2008, 11:00 PM
Post #11
QUOTE(dwnthehatch @ Apr 22 2008, 06:35 PM)
[right][snapback]155308[/snapback][/right]
Well, I guess I spoke too soon. My ABS and ESC lights have been coming on just about every time I drive my sonata now. Back to the dealer I go.
terkar
post Aug 18 2008, 11:31 AM
Post #12
Expert
Drives: 2009 mercury milan, 2007 Santa Fe limited, and 2009 Mustang
Don't feel bad, I'm on my 2nd brake switch at 44,000 miles. Good thing we have a 10 year warranty!
babstude
post Sep 5 2008, 01:07 PM
Post #13
Drives: 2006 Sonata
QUOTE(dwnthehatch @ Aug 18 2008, 12:00 AM)
[right][snapback]183702[/snapback][/right]
what was the outcome .. I am now getting the ABS/ESC OFF lights and was curious what the dealer found.
No New Posts Engine Shut Off
What's going on?
20 penguin_hash 662 Yesterday, 09:58 AM
Last post by: wagsmachine
No New Posts Engine Wont Start When Hot
4 kev f 125 28th November 2008 - 12:56 AM
Last post by: Madogi
No New Posts Engine Ticking
1600 kms
13 Pinto_Siftbean 755 25th November 2008 - 05:19 PM
Last post by: david-paul-1
No New Posts Engine Oild Change Interval ?
23 montclare 485 23rd November 2008 - 07:49 PM
Last post by: Propflux01
No New Posts Check Engine Light & O2 Sensor
4 radmacd 49 22nd November 2008 - 04:19 PM
Last post by: radmacd
2nd December 2008 - 07:22 AM
