Hi Mazen,
Surprising as it sounds, the mileage on this car is probably correct. It was imported into Sri Lanka in 2002 by an army guy who hasppened to have a coveted duty-free import permit. He then stored it and defininitely didn't use it for the 6 years between then and now as I was the first to register it in Sri Lanka a few months ago. Also, most things about it are pretty near mint condition. Nothing looks like it's 8 years old.
I'm still in the wilderness here in the mountains but took it to another mechanic in a tiny garage who did a strange thing. He took out two of the relays from inside the fuse box and swapped them over (or so he told me). Amazingly, although I've only driven it about 20 Km since then, the problem with pinking and spluttering before cutting out every few Km have gone away! He tells me I shoudn't try to run it without the a/c on until I get the relays replaced (why???). I don't yet know about the fuel consumption and the exhaust seems pretty hot still but suppose it would anyway :P The engine warning light remains lit though.
Rich T, I checked the forum carefully and had read everything I could about the O2 sensors too. Would be very interested to know what happens if you change your sensors. I have read that just removing the cat upsets the ECU no end, if that's not true I'd love to tear it out by the roots. Maybe also, although my car has a low mileage, the cat may have degraded with age. It all seemed to happen quite suddenly though. From no problem, to light on to pinking and cutting out occurred over less than 200 Km. Interestingly, the warning light started flashing on and off just as the pinking started.
Thanks very much Mazen for the user handbook. Really kind of you to send it. I'll go through it now and check what that flashing light meant.
Thursday, I'll get the car to the only Hyundai garage in the country and see what they say. They were singularly unhelpful about the crankshaft position indicator problem (see other thread).
Hey, I checked carefully my consumption on the last tank of petrol, it comes to 4.2 Km per l. Might as well trade it in for a tank!
Thanks again guys!
