Sorry to jump in on the thread. I too have a lantra 1.6 si(99 though). I tried to remove the brake drum on Friday but i couldn't get it off. The two screws were removed and i tried bashing it off with a hammer.
Do you need to remove the wheel nut first? What should be done with the bent metal just in front of the wheel nut? Can it be simply bent out of place when removing the wheel nut and then bend it back after refitting the wheel nut? I believe its acting like a split pin.
Is there any way to slacken off the brake shoes before removing the brake drum? Just in case there is a lip on the brake drum.
Hope to hear a response soon,
Rob
I don't have a clue about the brake drums personally. If they are anything like the disc brakes then they probably awkward to get. When i bought front discs for my Lantra, Hyundai only produced about 6 months worth of Lantras with the discs that were on my car. (or so my local parts shop tells me)
This post has been edited by Shocker_Carn: May 11 2008, 03:32 PM
