QUOTE(Rich T @ Apr 6 2008, 10:44 AM)
Problem with Oxygen sensors. fAULT CODE on ECL indicates PO421 Catalyst efficiency fail. 5 Oxygen sensors fitted to my model.
Anyway of isolating the fault code to an individual sensor?
[right][snapback]149343[/snapback][/right]
There are only 2 O2 sensor in the Jet. Sould be the same for most model, mine is 2004.
1st one is located before the 1st CAT, this is used by the ECU to monitor the oxygen level in the exhaust during closed loop mode.
the 2nd O2 is located after the 2nd CAT to detect if the CAT is heated up and working properly.
Just replace the 2nd O2 sensor and it should be fine.
