Usb Port - Laptop Hardrive |
Apr 5 2008, 02:40 AM
Status:
Drives: i30
I have an i30 Diesel Automatic and I think its great !!
The problem I have is that I want to plug a small laptop drive up through the USB port
Unfortunately the stereo does not recognize the drive when it plugged in
I have formated it as FAT32 (Like the instructions tell you do do) and I have tried it with a 150, 30 and 1 GB partitions but it still wont work
Does anyone know how to get this to work ?
Apr 5 2008, 03:40 AM
Status:
Drives: 2008 Hyundai I30 SX CRDi
QUOTE(kasia3 @ Apr 5 2008, 06:40 PM) I have an i30 Diesel Automatic and I think its great !! The problem I have is that I want to plug a small laptop drive up through the USB port
Does anyone know how to get this to work ? [right][snapback]149137[/snapback][/right]
Could it be that the current requirements of the laptop HHD are simple not available out of the USB port in the i30? I wouild expect that a simple USB drive would have a very low current requirement where as a laptop HDD my require a certain abmount in order to spin the motor in the drive. While desktop and laptop PCs have the capability to provide the correct power requirements through the USB port about 500mA IIRC, It could be quote possible that the i30 head unit doesnt allow this much current drain. As soon as i get my I30 i will perform a test on the current limits of the head unit as i had the same idea about the HDD, but really with 16gb usb sticks to we need this much music LOL Cheers WFC
Apr 5 2008, 03:26 PM
Status:
Drives: i30
Yea I can hear the drive spinning up and I have left it for ages but it doesnt seem to recognize it
I have 120GB of music and I was really keen to take it all with me as I drive heaps (Hence why I bough the diesel)
I must say its a huge disappointment I have been looking forward to it for months :(
Apr 5 2008, 05:33 PM
Status:
Drives: 2008 Hyundai i30 CRDi SLX Manual & 2007 Nissan Tiida Manual Sedan (Wifes car)
Hi There Kasia3 Don't despair, you can buy an 8gb flash drive which should work in the i30 from only $55. See link...(havent dealt with this crowd and would need to be able to return it if not compatible) http://www.rbp.net.au/?gclid=CJOhqbD6xJICFQcwiQod4HIinABy my reakoning thats about 2000 x 4mb songs. Might be best to buy one locally for a little more so you can swap it with another if have a problem. Regards, Dazz :thumbsup:
Apr 5 2008, 06:38 PM
Status:
Drives: i30
Has anyone had anything bigger then a 8GB drive work ?
I have seen 16 and 32 GB drives
Apr 5 2008, 11:53 PM
Status:
Drives: 2008 i30 CRDi 1.6 SLX (plus 2007 1.6 Getz Click)
Hi all,
I'm working on this and having some success. I have partitioned an 80gb drive into three drives, each formated as FAT32. The partitions are: 29.2Gb, 29.2Gb and 15.9Gb
I have heard that some older PC USB ports do not deliver enough current to get drives spinning. I have also read that older 2.5" drives needed more power to get them spinning. Hence a lot of drive cases have double USB connectors to plug into a PC. In my experience, newer 2.5" drives can operate successfully with a single USB connection.
I placed different albums in the last and smaller partion, the head unit recoginsed them and they played successfully.
Next I tried placing an album in each partition and away it went, no problem. Each album was recogised and played successfully.
Next, I placed all the albums in the first partition and again had success.
It appears that FAT32 partitions can not be greater than 32Gb under Windows XP, so my next experiement will be to use themaximum partition size of 32Gb for one drive and format the remainder as NTFS and see if it will work.
I'll keep you posted.
Bob
Apr 6 2008, 06:17 PM
Status:
Drives: 2007 Hyundai i30
I just bought an 8GB USB flash drive to try in my i30 and unfortunately it doesn't seem to work.
It'll play alright for a little while but eventually, it'll just freeze up, especially if I skip tracks or use random play.
My 2GB drive plays fine though.
Has anyone else tried 8GB or larger USB flash drives in their i30 (mine is an SX)? I'm wondering if it's a problem with the stereo or just a crappy flash drive (works fine in the computer though).
Apr 9 2008, 11:07 PM
Status:
QUOTE(happynoodleboy @ Apr 7 2008, 10:17 AM) Has anyone else tried 8GB or larger USB flash drives in their i30 (mine is an SX)? I'm wondering if it's a problem with the stereo or just a crappy flash drive (works fine in the computer though). [right][snapback]149606[/snapback][/right]
Never mind, it was just a crappy flash drive. Swapped it for a "brand" one which works fine. I got an official reply from Hyundai that there are no foreseeable limits (within reason) to the size of a flash drive that can be used by an i30 stereo. I guess the only real limit is the FAT32 filesystem.
Apr 10 2008, 03:08 AM
Status:
Drives: i30
From what I can tell its a power problem, I use my 160GB drive on an older PC and it did not work
Anyone got any ideas on how to boost the power from the USB port?
Apr 11 2008, 05:18 PM
Status:
Drives: i30
I found an old laptop that had a 20GB hard drive in it, so I used it and that works great I didn't change the cable or the caddy just the drive and now it works. Shame my 160GB drive will never work but 20GB is still good enough to carry my favorites and some new albums I think your right about trying to get a low powered drive Overall it looks like Hard drives work provided... 1) Its formatted no larger then 32GB using FAT32 2) Its a drive that can run off lower power Use this link below, it compares drives based on max power consumption, there is a huge different between power usage but if you buy the one that uses the least power then you will have a better chance of it working http://www23.tomshardware.com/storage25.ht...2=414&chart=157Good luck
Similar Topics
Similar Topics
Topic
| Replies
| Topic Starter
