QUOTE(Shambles @ May 6 2008, 01:38 PM)
Right. Since this post (1st April) I've been measuring my pressures weekly with a digital dongle doodaa from Maplins. Dunno if our Oz boys have a Maplins store, although I imagine it's not an exclusive to them.
When cold, this device shows a beautiful 32psi all round for all tyres. It also includes a digital depth gauge which is showing on the pic.
Always good to keep an eye on pressures as even a small reduction in the recommended figure can affect performance and handling.
So I've been told.
Yeah - I balanced it on my rear wheel just for the effect :w00t:
[right][snapback]159173[/snapback][/right]
Hey Shambles in the pic she is reading 28.9 mate?
i put a healthy 34.5psi in mine all round as i always like a few pounds more, no problem and tyres seem to stay cool this just means they will last and hot tyres just mean more friction. more air helps them roll easier so less resistance less fuel, thats if you drive carefully, just could have less traction in the wet you just have to test.
i just use a digital gauge that you push down on tyre valve like normal, have my own air compressor so always check and set them cold at home.
