Hey
ive had this problem on alot of cars before
usually your turn signals wont work but your hazard lights will (4 way flashers)
it will most likely be whats called your "Thermal Flasher"
its the resistance coil that takes up the charge to create the delay between flashes
i dont know what they run for these vehicles but im sure a wrecker will have one
it should be located under the dashboard on the drivers side, take it out and take a multi-meter to it and check connections
hope it helps, let me know how it goes
