> New To The Site Please Help!, Car Will Not Start!!!
ASILAYDYING83
post Mar 27 2008, 05:41 PM
Drives: 2001 Hyundai Accent GS 1.5
i recently got a obd II actron scanner for my hyundai 2001 accent and checked for codes...and the code P0118 came up which is the Ect Sensor (engine coolant sensor) but then replaced it with a new one and scanned it again.... nothing came up it said no codes found..Pass....but the car didnt start!!! whats wrong what do i do???
NovaResource
post Mar 27 2008, 06:56 PM
Drives: Nautical Blue 2006 Tucson 2.7L V6
First thing I would check is that you make sure everything you touched during the sensor changed was put back correctly. Like if you disconnected the battery that all the cables are re-attached and tight.
ASILAYDYING83
post Mar 27 2008, 07:13 PM
yup i tried and check all the wires and everything seems to be fine and the car won
't start what do i do??? starter fluid didn't work
NovaResource
post Mar 28 2008, 08:05 AM
Does the engine crank? If the engine cranks with the starter, I would check the ignition coils first.
ASILAYDYING83
post Mar 28 2008, 01:09 PM
ya it cranks i even replaced the coils with a new one and it still wasn't starting....ahhh what do i do??
cstephen
post Mar 28 2008, 01:49 PM
Drives: 2001 Hyundai Accent GS Automatic
I just got through going with this no start problem with my '01 accent.
Mine was the Crankshaft Sensor. I replaced it with an after market one from Autozone and it still ran sometimes and other times would not start. Turns out the sensor was a little different in size than the original one and the bolt that held in the original sensor was too short, causing an intermittent connection. The dealer did diagnosis and found out this was the problem, put in a longer bolt to hold the sensor in tight and my problem went away.
It's a long shot, but you could have a bad connection at the coolant temp sensor. I was getting a code for the crank sensor, and after I replaced it, it went away, but the car still would not start.
Also, make sure nothing is unplugged (Although you have probably already done that).
ASILAYDYING83
post Mar 28 2008, 01:59 PM
i did notice the new sensor was a little bigger than the old one...
should i take it to autozone and let them diagnose it or what???
help!!!
ASILAYDYING83
post Mar 28 2008, 10:39 PM
where is the crank shaft sensor located??
where can i see a diagram?
help!!!
J..M
post Mar 29 2008, 05:27 AM
Group: Validating
Drives: 2001 Accent 1.3i
Slow down ..... Geebers ...... Try hooking up the old coolant sensor & see if it goes then
ASILAYDYING83
post Mar 29 2008, 09:54 PM
i did and still nothing...
where is the crank position sensor located??
J..M
post Mar 30 2008, 01:44 AM
Post #11
Group: Validating
Front wall of the block...... Its all guesswork now tho, as Hyundai's "Fantastic" :innocent:
OBD system seems to be failing you. (Don't take it personally, theys pretty poor all the way round)
They seem to work heavily in tandem with the Camshaft sensor & the two seem to fail with amazing regularity. The two being simple two wire hall effect switches makes the testing of the units pretty ..... Well impossible really.
So I guess you could well be replacing both...... Past experience would suggest that you you get both & replace as a pair, otherwise this job is going to drag on & on & on :(
ASILAYDYING83
post Apr 1 2008, 06:35 PM
Post #12
how much do those two run for??
J..M
post Apr 1 2008, 06:46 PM
Post #13
Group: Validating
Google fourgreen & send em ya Vin & they will tell ya pt #'s & prices
ASILAYDYING83
post Apr 11 2008, 09:23 PM
Post #14
i heard the crank sensor doesnt come up on the obd II scanner
why is that??
btw is the etc(engine temp. coolant senor) required to start the car??
thanks...
cstephen
post Apr 12 2008, 08:15 AM
Post #15
It came up on mine when it initially failed. I got an error code.
However, I replaced it, and the code went away but the car still wouldn't start!!
I learned that I replaced mine with an aftermarket sensor, and the length was different, therefore the bolt holding in the stock sensor wasn't securing it tightly enough, so the dealer put in a longer bolt and tightened it up, presto, it has worked fine ever since. Make sure those sensors are making contact, and that they're snug and securely held by the bolts.
ASILAYDYING83
post Apr 14 2008, 10:51 PM
Post #16
koo thank you sir!!!
No New Posts Topic has attachmentsNew Subwoofer Enclosure
1 PastorK 10 Today, 10:49 PM
Last post by: Unfated
No New Posts New Blizzaks
Winter tire shortage in Canada
2 Valk 39 Today, 10:38 PM
Last post by: Valk
No New Posts Newbie To Forum
2 Dbecks51 14 Today, 10:14 PM
Last post by: trajetXG
No New Posts The Multifunction Car Dvd Player Cdp0005
1 timusacs 17 Today, 09:16 PM
Last post by: gravelhighway
No New Posts New Plugs?
Maintenance questions
2 muser3 11 Today, 08:11 PM
Last post by: muser3
2nd December 2008 - 11:11 PM
