Cold Weather Creaking Noise In Cargo Area |
Mar 26 2008, 09:42 PM
Status:
Drives: 2007 Hyundai Sante Fe 3.3
QUOTE(Don67 @ Mar 26 2008, 11:38 AM) Has anyone encountered a cold weather creaking noise coming from the interior cargo area? It sounds like a piece of plastic being twisted every time the body leans into corners or rolls over lumpy ground, and is quite noticeable given the otherwise quiet interior. I sprayed tire dressing on the hatch seals but no luck. Suggestions? [right][snapback]146488[/snapback][/right]
Whenever I was looking for a water leak in the trunk, I would put someone in the trunk and spray it with water. The same principle for a noise in the back. Drive with the same road conditions with a friend in the cargo area. Good Luck Gord
Mar 27 2008, 05:11 AM
Status:
Drives: 2008 Santa Fe GLS AWD
QUOTE(gllund @ Mar 26 2008, 10:42 PM) Whenever I was looking for a water leak in the trunk, I would put someone in the trunk and spray it with water. The same principle for a noise in the back. Drive with the same road conditions with a friend in the cargo area. Good Luck Gord [right][snapback]146619[/snapback][/right]
Thanks Gord, I had the same idea after posting this topic. I backed up and down the driveway with our kids squatting in the trunk (which is lots of fun by the way... especially when you tell your curious neighbour that this is the only way to deal with little brats who WON'T STOP KICKING THE SEAT). Turns out the noise is coming from inside the driver's rear pillar, so this will take a bit more work...
Mar 27 2008, 02:20 PM
Status:
Drives: Santa Fe 2007 3.3L
Experienced an odd creaking noise in my Santa Fe as well. Took it to the dealer who sent it out to a body shop to weld some pieces that weren't done properly in the factory. Not sure on the specifics, but it took them a few days to do it (got a loaner from them in the meantime). It was a pain in the butt, but the noises are gone.
This post has been edited by cephas: Mar 30 2008, 07:36 PM
Apr 6 2008, 09:41 AM
Status:
Drives: 2007 Santa Fe SE 2WD Silver
I have been getting the same creaking noise for a few months now. My wife drives the SF most of the time and I have not yet found the culprit. I tried adjusting and lubricating the rear hatch but no success. I will stick my daughter in the back and do the driveway shuffle to see if she can find it ? I think it's in the rear pillar as well. What is with the creaks and noises on the SF ? I might be a Little OCD but I sold my Chevy so I could have a nice quiet Hyundai !
May 19 2008, 07:50 PM
Status:
I'm still getting this same creak sound and it's starting to drive me crazy! I tried sitting in the cargo area while my wife rolled the SF up and down the driveway and sounds like it's in the lower rear side panel area but I can't get to it. I removed the tail light and trimed some flashing but no results.
Don67 where exactly did you spray the lube ?
May 20 2008, 03:51 PM
Status:
Thank You, I'll give it a shot.
Vctr
Nov 14 2008, 05:50 PM
Status:
Drives: 2007 Santa Fe GLS 3.3
QUOTE (Don67 @ Oct 13 2008, 04:54 AM)  Mystery solved. There is a new technical service bulletin for this problem. I had this done last week by my local dealer. They were a bit confused that I was bringing them a TSB that apparently "doesn't show up in our system", but they did the work under warranty and the vehicle is now creak free. The next mystery to solve is a rattle that seems to be coming from the rear passenger door pillar.
Similar Topics
Similar Topics
