Ok now that i figured out where the fuel pump is i have another problem. When the car was hit the radiator smashed the shifting linkage connected to the top of the transmission down. it is now jammed into some gear. Idk which. i tried pullin and hittin it back up with a hammer, but the linkage will not pull up. its a 5 speed incase no one has found out. the shifter moves easily forward and backwards but side to side it is jammed. any ideas? maybe my tranny is shot? Thanx Again, Joey
