> Engine Light/gas Up Problems
Giller2
post Mar 17 2008, 12:39 PM
Drives: 2002 Hyundai Sonata GLS 4-cyl
Hey all...02 Sonata 4cyl gls. My check engine light has come on, and now I can't put gas in it. Start putting gas in, it just burps back and shuts off the pump. Pump again, same thing. Takes like 10 minutes just to put a few dollars into the car as it keeps shutting off, no matter how slow you try to trickle the gas in. Any thoughts on this combination of probs? Also seems to require more pushing on the gas pedal at takeoff to get it to kick in. (More resistance in the pedal). This may just be my imagination, but the light and gas issue aren't. Please help!
Jean
post Mar 17 2008, 06:08 PM
Drives: 2002 Hyundai Sonata 2.7
I have similar problems with my 2002 6 cylinders Sonata. I have check engine light on after re-fuelling and goes away after one or two days later. Last refill, it stops by itself, at least 5 times but i was able to fill it up completly. I have no power issues when running. Starnge.....
italian54d
post Mar 17 2008, 07:13 PM
Drives: 2002 sonata 2.4
try reseting your computer drive around to normal temp then take the neg(-) of the battery wait 5 mins then hold on the brake for a few seconds to kill any power thats left in the lines then hook it back up and drive it like you stole it for a little while computer will get used to your driving pattern
Jean
post Mar 17 2008, 07:33 PM
How do you reset the computer?
Giller2
post Mar 17 2008, 07:55 PM
I've had the light reset on mine....and resetting still won't fix the gas issue. Is there a flap inside the tank that might be stuck or something?
italian54d
post Mar 17 2008, 07:57 PM
Firstly bring the car to normal operating temperature by driving for 15 minutes or so.
Now open the bonnet and disconnect the earth lead from the battery, ensure this is not touching any part of the bodywork - insulate if necessary - and wait 5 minutes.
Next depress the foot brake for 20 seconds - this will completely discharge the ECU's capacitors via the brake lights.
The next step (to be carried out immediately, while the engine is still warmed-up) is to carefully re-connect the battery earth lead, close the bonnet and now drive the car in a spirited fashion (accelerating rapidly through the gears, full-throttle straights etc. etc.) for a full 30 minutes. Try to choose a quiet time on the roads for this, (i.e. early on a Sunday morning!).
This period of driving will `re-educate` your ECU into adopting more aggressive timing curves and alter the fuelling to match. It will also allow the unit to recognise any modifications you have made and to react accordingly.
If, on the other hand, you are not interested in outright performance, but are more concerned with economy and flexibility, use your normal driving style during this 30-minute run!.
racecar01
post Mar 17 2008, 08:03 PM
Drives: 2001 accent 1.6
It is more likely your charcoal canister not letting your tank vent. Therfore not letting it fuel properly and also the cel would come on for that. Just a thought though. Good luck
Giller2
post Mar 18 2008, 04:07 PM
Interesting. Charcoal Cannister, eh? Is that a diy type of job, or mechanic needed?
racecar01
post Mar 18 2008, 06:37 PM
The charcoal canister should be located behind the drivers rear whell not too difficult. Might get a better opinnion first and at least check the code because the canisters are not cheap. let me know.
baeball
post Mar 24 2008, 12:55 PM
Drives: 2002 Sonata
I have had the dsame problem with trying to fill up on gas. I have had it worked on 2 times at the shop. They seem to fix it for about 1 month and then the same thing keeps happening. I am looking for a fix also. Same year and Make, 2002 Sonata
Giller2
post Mar 24 2008, 04:15 PM
Post #11
Do you know what they worked on in the shop those two times? Be nice to narrow it down right off the bat.
baeball
post Mar 25 2008, 08:03 AM
Post #12
Drives: 2002 Sonata
Yes they changed the Charcoal Cannister both times, they told me because I live on a dirt road this will keep happening. I just want to know if there is a fix for this. I have called my Local Hyundai dealer and theyact like this is not a comon thing.
rahjama
post Mar 26 2008, 12:21 PM
Post #13
Drives: 2001 Hyundai Sonata
I don't know how to fix this issue but I could suggest a work around until somebody figures it out.
1. Buy a Gas Can
2. Fill The Gas Can
3. Use the Gas can to fill your car.
Sort Em
post Mar 31 2008, 10:09 AM
Post #14
Drives: 2009 Hyundai Sonata GLS manual
I hope this helps you out a little.
I used to be a service advisor and a mechanic for a dealership and I will explain this as best as I can for you.
The CHARCOAL CANISTER is part of the EVAP system. This system is made to vent off harmfull fuel vapors from the fuel tank. And yea, you can thank the federal government for that system.
The system will purge off the harmful vapors once the vehicle is in motion, it WILL NOT purge it while you are sitting still.
The Valve that allows this purge will close at a stand still, not letting fuel to re-enter the filler neck. At Idle the vapors are redirected to the charcoal canister to be dispursed after the vehicle is in motion.
Doing the following will cause these problems:
1: Topping off the tank. If the filling station pump stops, don,t try to even up the dollar amount. Once the tank is full there is nowhere else for the fuel to go but in the filler neck............ then the charcoal canister once the system is activated.
2: Leaving the vehicle running (or ignition on ) while trying to fill up leaves the EVAP system active. The system closes the valve when the vehicle is not in motion, then soaking the canister, and causing a non fillable vehicle.
3: The cylinoid has been siezing up. This would cause a no fill condition.
4: The filler neck hose has a block in it. Sometimes caused by accidents/ repairs.
I hope this has helped :57:
baeball
post Mar 31 2008, 03:03 PM
Post #15
Drives: 2002 Sonata
I read that you said to not fill up when the car is running, my wife does this all the time during the winter when it is cold out, I live in Minnesota. I bet this is why, now what do I have to do to get it back to normal? I am guessing this is the reason.
baeball
post Apr 9 2008, 09:47 AM
Post #16
Drives: 2002 Sonata
Ended up taking charcoal canister off and blowing it out works fine now, better than bringing it back into the shop and paying for a new one. Whish I would have done this the first time.
Jean
post Apr 9 2008, 05:58 PM
Post #17
Was it difficult to locate and remove? Can you explain how did you get to it? On the Hyundai service websit, very confusing.
Roadracer
post Apr 9 2008, 06:11 PM
Post #18
Drives: 2002 Santa Fe AWD
A couple of comments to make.
One, fuelling a car while it's running is asking to get blown up. Stupid move, period. The car is not grounded, and having it running is a source of ignition, and fuel-vapour is ever-present around a gas station, especially when fuelling your car. It's not allowed in Canada for that reason. The gas-station attendant won't even turn the pump on here, until your car is turned off. You can research that to your own ends, but that's just plain stupid, and I live just north of the Minnesotan that made that comment. This is not a flame, btw, it's a fact, and winters get a lot colder where I am than where you are. Stay alive!
Secondly, if you're having trouble fuelling, it's like the fuel-tank vent filter that is plugged. It's there to vent off air as the tank is filled. If it's plugged, air can't escape and will cause the issue you're describing with no chance to fill the tank shy of trickling it in.
vaut1111
post Apr 16 2008, 05:50 PM
Post #19
Drives: 2002 Hyundai Sonata glx 2.7
Hello
I had the same problem on my 2002 . The check engine light and problems feuling the vehicle. The solution was replacing the fuel vent filter located just behind the drivers side rear wheel.
Giller2
post Jul 14 2008, 02:45 PM
Post #20
Hey all. As I started this, I should put my fix in here. The light is off! What did we do to fix it....nothing. I've found that if I fuel up my car, I need to put the nozzle in, then turn it so it's almost in upside down. This works. If I fuel it normally, the light comes on. Stays on. Only goes away when I refuel upside down. Weird, but works.
