QUOTE(ddown @ Mar 15 2008, 09:36 PM)
Anyone else notice increased valvetrain noise, especially when the engine is cold with synthetic oil? Pennzoil platinum 5w-30 in my case? I may just switch back to conventional oil.
What you might be hearing is injector noise. From this vantage point it's hard to say with any certainty but I've had this occur a lot when making the switch.
Certain filters might make a difference. You could try a switch but I've not found any, from my work, that do this on your eng.
I've seen/heard different engines respond differently to different oils when it comes to noise.
