> Need Help With Door Panel Removal, Interior door handle
owl1012
post Mar 11 2008, 01:02 PM
Drives: 1997 Hyundai Accent
Hello, I'm trying to replace the outside passenger door handle on a 1997 Hyundai Accent. I've had good luck, so far, in attempting to remove the interior door panel. For instance, I did manage to get the window crank removed with no problem thanks to the info I found on this board. However, getting the panel past the interior door handle is another matter. Anyone have some good advice. I've searched the forum and the Web for help, but I think I must need a little more help. Thanks.
Rod
Mithadon
post Mar 20 2008, 12:28 PM
Drives: 1998 Hyundai Accent GL
As long as the rest of the door panel is off, the door handle shouldn't be too hard. The crank/lever for the window is by far the hardest part. (just to make sure, I have a 98 Accent GL. Anyone, there are two ways to get the door panel off the door handle. One, unscrew the door handle, and turn it a little sideways to get it past the hole in the door panel. Two, the door handle works rather simply... all it does is pull on a metal rod connected to the door latch, so there's part of the door handle that's a pin/clip (blue in my case) and fits into another plastic piece at the end of the metal rod. If you can just manage to push the clip out with a screwdriver or something, you can simply take the whole handle off along with the door panel.
Be careful though, as the handle has two clips at the back that go into the metal sheet of the door (they don't clip, but slide in), so after you unscrew or whatever, you have to push the handle towards the front of the car a little bit so that those come out of their slots.
I just made a whole post about removing the door panel and the handles... Once you get the panel off, (you'll have to rip the plastic sheet after, probably), you can unscrew the outside handle... there's two screws, one of which also locks the lock cylinder onto the handle. But theres a whole lot of other things holding the handle, so you might want to take the whole thing out along with the latch and interior handle, then work on it. Good luck!
this is the post:
http://www.hyundai-forums.com/t24804-fixin...-door-panel.htm
This post has been edited by Mithadon: Mar 21 2008, 03:03 PM
No New Posts Need Help With Sonata Bolt Pattern
12 MsSonataLuvr 83 29th November 2008 - 08:01 AM
Last post by: nds
No New Posts Need Some Help(lantra 94 Mods)
1 Madogi 15 28th November 2008 - 12:46 AM
Last post by: Madogi
No New Posts Help, My Accent Doesnt Start!
1 claudio_CR 221 27th November 2008 - 02:22 PM
Last post by: jyoung1z
No New Posts Help! Chripy '06 Elantra...
3 TL1201 40 26th November 2008 - 01:16 PM
Last post by: TL1201
No New Posts Topic has attachmentsHelp! Hitch Weldnut Missing!
Trying to install hitch. One hole biggr
8 dbldwn02 363 15th November 2008 - 10:43 PM
Last post by: dbldwn02
2nd December 2008 - 10:30 PM
