QUOTE(brian2000 @ Mar 9 2008, 05:17 PM)
I have already tryed to go on the hmaservice.com
It doesn't like anything but Microsoft Internet Explorer for setting stuff up I found
Do the Lower A, Tie Rod & Lower strut bolts with a std size socket, nice & tight but don't go mad. The Large Axle nuts (I take it you have replaced them, cos they stretch when you do em up) do as tight as you can with a std socket wrench then use a 18" handle & turn them half a turn more.
The wheels nuts, contrary to popular belief do not have to be done up mega tight & then have the wrench jumped up & down on...... Just do em up goodly tight with a std sized wrench with your hands .....
Jobs a good un ....... I do hope you have used anti seize on all these bolts...... What you haven't...... Your funeral :57:
