Hi Montego, thanks for the reply.the fridge is in the caravan, I have fitted the towbar and 12 N lighting electrics to the car for towing the trailer\caravan but the 7 Pin 12S electrics requires a 12v line, always live to be routed from the battery to a relay.
I thought I could feed from the 12v socket in the rear of the car but its a switched 12v line so goes off when the ignition is switched off which is no good for the fridge in the caravan.
I thought I could route a cable direct from the battery, I have routed a cable from the rear to the front of the car but I cannot figure out how to get the cable from inside the car to the engine bay, I could drill a hole but I am reluctant to do this as I am sure there must a either a live feed I can splice off or alternatively somewhere to feed into the engine bay with out resorting to the drill. Any ideas?
