 Hyundai-Forums.com > Technical > Car Audio, Video & Electronics > Wiring Scrolling Led Plate Frame 2007 Accent
 Wiring Scrolling Led Plate Frame 2007 Accent, um, how? what wires? (not working...)
ewing
post Mar 5 2008, 09:13 PM
Expert
Drives: 2007 hyundai accent sport
Status: OFFLINE
the plate frame & remote control work as tested directly from the battery post terminals.
we found an apparently always hot wire inside the hatch that powers the lock actuator when the remote control for the locks/alarm is pressed. with the car off, it reads a constant 11 volts.
there's a cluster of black wires coming to a common ground point. this MUST be the ground. also, we were able to get a reading off the circuit - so it must work.
i believe the plate frame is a 12V product. are we simply not getting enough voltage??
when connected directly to the battery, the plate frame automatically turned on. we could turn it on and off with the remote.
when connecting the red & black wires to the always hot latch actuator wire & the ground cluster, it doesn't turn on. nothing happens. the remote won't turn it on?
hrmm... confused.
shouldn't this be how to connect it?
...lost. any help/advice is appreciated. :beer: :)
User is offlineProfile CardPM
QuoteReply
ewing
post Mar 7 2008, 02:07 PM
Expert
Status: OFFLINE
just in case anyone's reading this for their own info:
i talked to an electrician who's wired a lot of motorcycles.
he said being a 12v appliance, it won't even turn on with an 11v source.
the battery could be damaged, but more likely the wire back there is too thin and there's a voltage drop to only 11 when the car is off. try doing it with the car on. will try that.
also, since i want to hook it to an always hot wire, the only other one back there i can think of is the turn signal bulbs - since they blink when you use the automatic locks/alarm fob. he said those are typically a larger gauge. next step is to remove trim to access the hot wire going to the turn signal & test it for voltage with the car off. if it's 12 or more, we're in business with that one.
*crosses fingers*... 'cause i really REALLY don't want to have to run a wire right from the battery.
QuoteReply
troyx87
post Mar 25 2008, 07:14 AM
Drives: 2002 Accent
Status: OFFLINE
The turn signal lights wouldnt be 'hot' all the time though would they? Only when turning?
Also, what is this thing you're trying to install? An LED frame around the number plate? Never seen one before...
QuoteReply
noobliterator
post Apr 4 2008, 09:58 PM
Drives: 07 Accent GS 1.6 AGU, '97 Trans Am 5.7 LILLIAN, '92 Sunbird LE 2.0 ANA, '99 Cutlass GL 3.8 CHANNON
Status: OFFLINE
Hot all the time just means that they have power at all times, not that they are always on. That is controlled by a switch in the turn signal.
QuoteReply
> Link To Us
> Similar Threads
Under-dash Led's
Forum : 3G (2006+) Accent
hoosieraccent 198 16 Today, 08:47 AM
By: Torbo1
2000 Accent 1.5 Check Engine Light
Forum : 2G (2000-2005) Accent
Discman 307 8 Today, 08:47 AM
By: TommyR
What Gas Mileage Does Your 90's Accent Get?
Forum : 1G (1995-1999) Accent
user7 578 8 Today, 08:38 AM
By: Percy90
Accent Transmission Problem
ahs2m2 10 0 Today, 05:59 AM
By: ahs2m2
Cold Air Intakes For 2007 Santa Fe
Forum : 2G (2007+) Santa Fe
bwatson 728 8 Yesterday, 03:45 PM
By: blackfrontier
7th September 2008 - 02:56 PM
