hi .. mine is without airbags but with my general knowledge I can tell you that this is normal , if it is still blinking after ignition key is on and don't turn off then this is abnormal and indicates a problem in the airbags system , take it as a rule , all lights should turn on when ignition key is on then all of them should turn off after starting the car , if any light stayed on then this indicates a problem , so don't worry , nothing wrong
