2001 Accent Will Not Start, Turns and turns, but no fire. |
Mar 3 2008, 05:37 PM
Status:
Drives: 2001 Hyundai Accent GS Automatic
(I already replied in the thread titled 2002 accent won't start, but I'm starting a new thread in case my situation is different, or anyone else has any suggestions...Thanks!)
Hey All. I have a 2001 Accent, 54K miles (Sig needs updating) and automatic trans. Always runs beautifully.
In January, I was travelling, when I stopped somewhere and turned off the car. When I got back in the car 20 minutes later, it would not crank. I kept trying off and on for the next hour and it finally cranked. Car turned and turned like it was trying to crank, but not getting any spark or fuel.
Instance Number two: February - car would not crank after sitting for a day or so. It finally cranked after ten minutes. Same thing.
Instance Number Three: March - Got home this morning from a trip out of town this weekend and turned off the car. Got back in the car three hours later to head to work, car will not crank. It still will not crank. I have tried everything. It's storming bad so I can't get out to check for spark. But the battery is not even two years old, and the plugs and wires were replaced last month.
This is very frustrating. I am starting to feel that I can't trust the car. Someone suggested the Crank position sensor. How can I tell if this has gone bad and how do I replace it. Any other suggestions? My main problem right now is time wise, I'm very limited in what I can do. I just don't have enough hours to sit and wrestle with it.
I have checked the HMAservice site. Can't find anything about crankshaft position sensor.
I'm lucky that I have an older (and unfortunately...more reliable) car that the wife and I keep as a backup for situations such as this. I'm trying to avoid a tow to the dealer for repair, but I am tired of this car screwing with me.
Thanks!
Stephen
Mar 4 2008, 04:13 PM
Status:
Drives: 2001 ACCENT SOHC 1.3
Immobilise system?
Mar 10 2008, 08:30 PM
Status:
OK, this is really weird. I didn't have much time this weekend, other than to change the CKP sensor on Friday afternoon. We all know that the car didn't start. Saturday, the car didn't start either. Sunday, nope. Monday, I gave up. I called a tow truck to tow it to the Hyundai dealer. I go outside and put the key in the ignition for the tow man, and tried once more. Fired right up. At first, it was hesitant to fire but did crank. I turned it off and tried it again. Fired up again, but shook a little then smoothed out. Ran some errands around town and now it's firing up smoothly every time.
I still don't trust this car. It has a mind of its own. I won't be going off on long distances until I know for sure that it's running right.
The thing is...once I replaced the CKP sensor, the error code went away on its own immediately, without me having to clear it. Subsequent readings from the OBDII scanner showed "NO CODES FOUND - PASSED".
But it still would not crank. So I'm going to drive it a week or so and see what happens. :whistling:
At least now it's running. :clap: Decided to run AFTER I'd already called a tow and made arrangements for the dealer to diagnose the problem.
At least now I can use my gas. Right before it quit, I'd filled the tank completely up and only gone a mile when it died at my house. And with gas prices, I had to drive my other car which has an even larger tank :w00t:
This post has been edited by cstephen: Mar 10 2008, 08:32 PM
Mar 24 2008, 09:28 AM
Status:
OK, the saga continues. I got the car back from the dealer on the 14th. He replaced the positive battery cable and claimed that it was corroded internally, causing the crank sensor to not get enough voltage to start the car. Makes sense to me. Sunday, the 16th, the wife and I drove it down to New Orleans to the port to set sail on a 7 day Carribean cruise (A belated honeymoon - we were married in December). Car didn't want to start at first Sunday, but we were in a hurry to leave, so I took it anyway since the baggage was loaded in the car. Car ran fabulous. Got a personal best of 35.5 MPG highway with the AC on part of the way down to New Orleans. This was cruising at 68-70 MPH babying the right foot and not being hard in my driving.
Sunday, the 23rd, we arrived back in New Orleans, car had been sitting for a week. Didn't want to crank. I tried for a minute and it finally fired. It was semi-cold (in the 60's when we got off the ship in NOLA). Car ran great, and fired up as long as it was hot.
This morning: It's about 40 degrees out. It's only the second day I've tried to drive the car since I got it back. CAR WILL NOT CRANK!!!!!!!!!!!!!!!!!!!!!! It turns and turns and turns but will not fire. I'm SO ****. I called the dealer and told him as soon as I get it cranked when it warms up I'm bringing it back to him and he can have it until it is cranking the first time every time.
I want to keep this car, I really do.
But I've never had a car that gave me such fits before. Ever. Even my 18 year old Chrysler that I drive as a backup when this one quits on me cranks the first time, every time and has never left me stranded - take that HYUNDAI!
I love this car, it gets terrific MPG and it has relatively low miles for it's age but I need something trustworthy.
In the past month, it has:
New Positive Battery cable and terminal
Crankshaft Position Sensor
Plugs
Wires
K&N Air Filter (It was doing this before I installed the air filter)
Mar 25 2008, 04:34 PM
Status:
Drives: 2002 Accent
Good luck mate, sounds like a very annoying problem.
I only got my accent on sunday, and dont know much about modern cars, but it sounds like its not sparking- maybe it could be ignition coils?
