QUOTE(trajetXG @ Feb 27 2008, 10:48 PM)
I don't think there's anyway to adjust the idling. Every thing is control by the ECU.
As for your problem, have you tried changing the Spark plug or check the cables?
i did changed the spark plugs last year, i used the recomended plugs for this model which they told me should last for at least around 60,000 to 90,000 km.
as for the leads, maybe i should try changing it too. tell me, if there is something wrong with the plugs or the leads, the car should at least be shaky and i could hear the engine sound like it's coughing or choking. but it's not, and upon take off from a full stop, i have no problem,it accelarates smoothly as if nothing's wrong. but i'll still do your avised and that of montego, thanks a million guys.....i'll keep you posted...... :460:
