QUOTE(Automatik S-Coupe @ Feb 20 2008, 04:55 PM)
the bosch number for the turbo injectors is 028015776 and thats are 191,8cc and the NA has 149,8cc injectors
[right][snapback]138483[/snapback][/right]
Thanks for the Info Automatic... this is what i thought
QUOTE
Fuel Injectors (http://www.iformation.co.za/scoupe/gtvset.htm)
The fuel injectors fitted to the S-Coupe Turbo are a higher flow rate that those in the normally aspirated S-Coupe and Excel. As the Turbo motor produces more power, more fuel is required. The fuel injectors from the normally aspirated motors are not able to deliver the required amount of fuel, even at 100% duty cycle. Unfortunately both Hyundai and Bosch (who manufacture the injectors) are not will to give details on the flow rate of each car's injectors.
