Hi all,
The other day I removed the dash to retrieve the serial number of the radio, and today I put everything back together and now nothing works. when I open the door, the door open light on the dash is displayed but very faint, the security light on the radio and the car immobilizer all Flash.. but if I go to start the car or even use anything that requires power (ie. breaks, lights etc..) those lights stop flashing. Did I miss something when assembling it again ? I try starting the car but it has nothing, doesn't even have that clicking sound when I turn the ignition. The battery itself was charged for a little bit and should of had enough charge to turn the engine over. I also checked the Fuses in the Fuse box near the battery which all seem fine. (not the ones under the dash).
Just wondering, is there any wiring around the dash area that could cause this ? I read that the hazzard/clock plugs have to go back in reverse order as you took them out... does it it matter if they don't ? I just plugged everything back in.
Also, when i did have the dash out (dismantled) everything worked fine, so I'm guessing something happened while putting it back together.
Car is:
1998 Hyundai Excel Sprint X3 - Manual
EDIT - Just went outside to have another look before pulling the battery out and onto the charger, and there was no power at all.. not even to the radio security/immobilizer.
This post has been edited by Widget: Feb 17 2008, 08:33 AM
