Engine seems to have lost power. Acceleration is very poor. Also I cannot get it to go much over 90kmh/60mph.
This is a 1999 Hyundai H-1 (Starex) van, 2.5L Regular diesel engine, no turbo, no rails, manual trans.
When I am driving quietly, you would not know there is a problem at all. But as soon as I press the gas pedal a little too much, the engine seems to give up.
It idles perfectly. However, when the engine is idling and I press the gas pedal hard, the RPM increases for a second and then goes back to normal idling. Also, when I do this, the "check engine" lamp lights up after a few seconds and remains lit until I let go of the gas pedal. Is this possible to diagnose?
The "check engine" lamp aslo flashes a second or so before engine startup, but it has always done that. Think this is normal?
I have done the basic stuff like changed the diesel and air filter and have run diesel cleaning stuff through the fuel. Do dice.
Thought diesel engines were simlpe, but now I am kind of out of ideas. Is there a gauge or something like the gasoline lambda sondes for diesel engines as well, or is the engine computer controlled or something?
Ideas please...?
Brgds Karsten
This post has been edited by karsteb: Feb 13 2008, 05:32 PM
