QUOTE(MsSonataLuvr @ Feb 11 2008, 06:46 PM)
Thanks guys! How about gettin the \hyundai symbol off the grille or the back...is that one i can just pry off?
[right][snapback]136286[/snapback][/right]
You can also use WD40 to get the sticky stuff off after the badge removal. Most people have at least one can of it around the house.
As far as the grill and trunk "Flying H" badges are concerned, I believe the one in the front is an integral part of the grill. The one on the trunk can also be removed using the heat and string method.
I am not totally familiar with the Sonata (I own an Azera and a Santa Fe)but I believe the rear badge is located in an indentation similiar to the Azera and Santa Fe.
By removing the badge you would have a strange looking indentation on the trunk with nothing in it. Many people are getting custom badging for the trunks after removing the stock badge.
Here is a link for one of the members on this site. You can see the custom badge he used for the trunk of his Sonata.
http://www.hyundai-forums.com/2007-Hyundai...item-cid653.htmHere is another link where you can find custom emblems for your Sonata.
http://www.koreanautoimports.com/store/ind...?cPath=31_23_75I have debadged both of my Hyundais and have even gotten the repacement grill for the Azera that does not have the "Flying H" in it.
Have fun with your car and let your imagination go wild.
David <><
This post has been edited by david-paul-1: Feb 17 2008, 11:42 PM
