 Hyundai-Forums.com > Hyundai Models > Excel Forum (Mitsubishi-Engined) > I Think I Have A Prob With My Clutch?
deathcab
post Feb 10 2008, 11:35 PM
Drives: 93 hyundai excel
Status: OFFLINE
I think the springs in my clutch busted, but i'm not sure. We had a heavy rain fall and flooded the streets on my way home i ended up driving through deep water, and the car drove fine and shifted fine, but the next morning the car wouldn't go into gear and when i put it in reverse it seemed to jump without me pushing the gas. A friend told me that the cold water, and hot clutch may have busted the springs? I've had the car for about 2 yrs now and i haven't had a problem with it, the transmission was re-built and some other work also before i bought the car. So i don't think it's the trans. If it's not the clutch what could it be? If anyone can help me with this or confirm that the clutch is the problem i'd be really grateful. Thanks alot everyone!!!! This car means alot to me.
willis
User is offlineProfile CardPM
QuoteReply
byronguidry3732
post Feb 11 2008, 11:58 AM
Group Icon
Group Icon
Group: Super Mod
Status: OFFLINE
Dear death,
How DEEP? Are we talking like 10 inches or like two feet? It is unlikely that your spring broke from water immersion but successfully drove home. Per the shop manual, you could have a cable operated clutch or a hydraulic operated depending on your date of manufacture. Do you know which one you have?
If you have the cable, check the both ends of the cable to see if either end broke. One end is attached to your clutch pedal lever under the dashbooard. The other end is attached to the bell housing. Attached File  1993_Excel_Clutch_Cable_1199341a.pdf ( 154.23k ) Number of downloads: 113
If you have the hydraulic clutch system, is your fluid contaminated with water? If yes or don't know, replace.
Attached File  1993_Excel_Clutch_Hydraulic_1199341.pdf ( 315.97k ) Number of downloads: 81
With the engine OFF, can you shift through the gears including reverse? Now, in a area clear from any buildings and obstructions, shift to first and start the car. Does the car move while the starter is cranking? Does the car start and not move?
Have a helper inside the car shift through the gears with the engine off again. You need to look at the clutch slave cylinder and the engagement fork under the hood. Does the rod in the slave cylinder try to extend when your helper pushes the pedal? Does the rod move the engagement fork? If yes, and yes, you do have something internally broken in your clutch.
Byron
QuoteReply
deathcab
post Feb 12 2008, 05:14 PM
Status: OFFLINE
byron,
ok the car does shift smoothly when the car is not on including reverse. Whether the clutch is hydraulic clutch or cable, i'm not sure. The water was at least over a foot. I'm not sure if there is water in the clutch fluid or not. How would i be able to tell?
Unfortunatly last night we just got a big ice storm, and i am unable to move the car away from the house, to see if the car moves when i put it in first and start it up. I will see if the slave cylinder and the engagment fork moves when i am able to get someone to help me with it. Thank you very much for your help. I will let you know what happens with this.
thanks
deathcab
QuoteReply
> Link To Us
> Similar Threads
Sonata Clutch 06-09?
Forum : 4G (2006+) Sonata
cajun 95 7 Oct 3 2008, 09:51 PM
By: Sequoiasoon
Accent Clutch
Forum : 3G (2006+) Accent
noobliterator 217 13 Oct 2 2008, 08:30 PM
By: crayb
01 Accent Clutch Replacement
Forum : 2G (2000-2005) Accent
truss64130 550 5 Aug 24 2008, 12:04 AM
By: Aussie Steve
1996 Lantra Sportswagon Clutch
Forum : 2G (1996-2000) Elantra & Lantra
pac 156 0 Aug 22 2008, 02:04 PM
By: pac
2004 Santafe Clutch Question
L8NITESURFER 224 1 Aug 22 2008, 09:00 AM
By: hinge817
6th October 2008 - 10:08 AM
