:00000732: xnetter from Canada!
Especially since you had numerous blown fuses from the alternator regulator failure (must have been generating >15 volts to blow fuses], go to
Fuse 5 10 amp A/T shift lever
Also, go to hmaservice.com. The entire fuse and relay component list is explained under ETM tab, Fuse and Relay information.
since you have a 99 Accent, you probably need to inspect each fuse in your dash fuse box. 15 volts in your system may have caused thermal fatique in your fuses. this is a hairline break in the fuse wire that may not be easily visible. Also, a fuse tester can be fooled by a thermal fatique break.
Byron
