 Hyundai-Forums.com > Hyundai Models > Azera Forum
> Broken Mounts For The Front Splash Shield, Watch out for parking lot concrete stops
david-paul-1
post Feb 6 2008, 06:10 PM
Expert
Drives: 2008 Chrysler Sebring Convertible Pearl Marathon Blue, 2007 Santa Fe Limited Pearl White
Ever since I first bought the Azera, I have noticed that the concrete barriers in parking lots often scrape the bottom of the splash shield.
Whenever I am approaching one of these barriers, I move very slowly so that if it starts to scrape the underside I can stop in time. It if doesn't scrape, I continue on until my front wheels touch the barrier.
Last night I encountered one of these barriers and thought it had cleared okay. Upon backing out of the space a bit later, it began dragging on the bottom of the splash shield and ended up breaking 3 of the four mounting points that are molded to the lower radiator support.
Early this morning I drove the Azera upon my ramps and began the repair job of epoxying the pieces back on the lower radiator support. After the epoxy cured, I was then able to bolt the front splash shield back in place.
All is good again. :)
Has anyone else experienced your Azera dragging on these concrete barriers?
For me, it doesn't scrape every barrier but often enough that I have to be very careful.
David <><
boppert1
post Feb 6 2008, 09:50 PM
Drives: 2006 Azera limited w/u.p.; 2003 GMC Envoy XL
I did once...only it hit the curbing with more of a solid metal thud than a plastic scrape. Didn't do any visable damage but it certainly scared the cr*p out of me...consequently I park much farther away from those things now.
cdmuile
post Feb 6 2008, 10:02 PM
Drives: 2008 Scion tC Release Series 4.0,2008 Nissan Rogue AWD
I noticed that right away having had my best beloved pull the whole front end off her '99 Cougar. In sub-zero weather she backed off very hard packed ice and snow that had been plowed up. The estimate was $1800 damage. I put it back together, believe it or not, with JB Weld. It lasted for two years until we traded cars. I listen very carefully when taking the Azzie up to a curb. I check for scratches under there often.
david-paul-1
post Feb 7 2008, 02:08 AM
Expert
QUOTE(boppert1 @ Feb 6 2008, 07:50 PM)
[right][snapback]135266[/snapback][/right]
The metal thud that you heard was when you hit the concrete stop with the steel rings that are welded on each side of your frame in the front of the vehicle. They are just a bit lower than the splash shield. When you hit these there is no harm done, only a little paint taken off of them.
David <><
boppert1
post Feb 8 2008, 11:49 AM
Thats what I had figured but it's a frightening sound nonetheless
rjgales
post Feb 16 2008, 01:04 PM
Drives: 2006 Hyundai Azera 263
Yes, Yes, I noticed The scraping right after I got the Azera and this was about the only complaint I ever had with my Azera. Recently on a very cold day I scraped a parking lot barrier and the whole splash shield broke off. It's a no brainer, I think the shield hangs too. Low. My dealer said Hyundai says not a problem. I don't agree. Dealer says $500 $US to replace shield, lots of labor "cause front bumper has to be removed. Anyone else with this problem. I need support for my claim with Hyundai.
david-paul-1
post Feb 16 2008, 03:20 PM
Expert
QUOTE(rjgales @ Feb 16 2008, 11:04 AM)
[right][snapback]137392[/snapback][/right]
As I said in my earlier post, I repaired the thing myself but it took me about 3 hours, not counting the time for the epoxy to cure.
To replace this unit would be very labor intensive. The bumper has to come off because the brackets that hold the splash shield on are molded into the lower radiator mount. The radiator mount is what has to be replaced.
If you damaged the splash shield, that would also have to be replaced but it is flexible and holds up better.
I'm not sure how we can help you with your claim with Hyundai. Unfortunately you, like me, hit the barrier and did the damage. If your insurance deductible is less than $500 you could put in a claim. My deductible is $500 so I decided to fix it myself.
Hopefully this won't happen to me again.
Your are absolutely right when you say there is a design flaw but there is nothing we can do about it except to be careful in the future.
Enclosed are some pics of my epoxied mounts. They are stronger now than when original. I also did some slight modifications so that the splash shield sits a bit higher.
Perhaps you or someone you know could do this kind of work for you.
David <><
Attached File(s)
Attached File  Splasn_Shield_Repair_001.jpg ( 419.32K ) Number of downloads: 91
Attached File  Copy_of_Splasn_Shield_Repair_002.jpg ( 187.54K ) Number of downloads: 68
Attached File  Copy_of_Splasn_Shield_Repair_003.jpg ( 151.13K ) Number of downloads: 65
Attached File  Splasn_Shield_Repair_004.jpg ( 372.62K ) Number of downloads: 53
Attached File  Splasn_Shield_Repair_006.jpg ( 338.66K ) Number of downloads: 72
rjgales
post Feb 18 2008, 09:46 AM
Thanks for the detailed info and photos on the splash shield problem. I know you can't help literally, but I'm looking for enough replies to make a case for exactly what you mentioned, a "design flaw". So far it looks like Hyundai is stonewalling it but if the car doesn't have proper clearance for conditions you would encounter in ordinary driving then by my definition I'd say they do have a design problem they wont admit. My car was delivered with this barrier scraping problem and I encountered it over and over again, I just wish I had brought it up with Hyundai early on after delivery of my Azera (best car I ever had! ). This damage was not due to careless driving because I too was careful to "sneak up" on those parking barriers, but I finally caught one, one time too many.
I would really like to hear from anyone else with this problem, especially if Hyundai did acknowledge the problem and paid for the repairs.
david-paul-1
post Feb 18 2008, 04:17 PM
Expert
QUOTE(rjgales @ Feb 18 2008, 07:46 AM)
[right][snapback]137891[/snapback][/right]
I will start a new thread regarding this matter. Hopefully, everyone who has had this problem will respond.
David <><
texas-azera
post Sep 10 2008, 12:21 PM
Drives: 2006 hyundai azera
I just repaired the same problem. $1900 at the body shop. Now my shield half way back on my passenger side broke off. I know they'll say it's my fault. Not enjoying the car I once loved these days.
campoly
post Sep 10 2008, 05:44 PM
Post #11
Drives: 2007 Hyundai Azera Limited/Ultimate, 2008 Mitsubishi Eclipse GT, 2003 Honda Accord, 1999 Mitsubishi Diamante
Welcome texas-azera!
QUOTE
I had that one fall off too. It was replaced under warranty. The service dude said it was replaced with a newer version so that it wouldn't happen again. Hyundai knows there is a problem with these shields. Don't let them tell you it is you fault (unless it is obvious that something was run over and tore it off :P ).
QUOTE
Welcome to the club. :beer: There are a number of us here who feel the same way.
Are you in N. Texas? I'm in the DFW area. I hope your dealer service dept. isn't as crappy as my nearby dealers.
texas-azera
post Sep 10 2008, 07:22 PM
Post #12
QUOTE(campoly @ Sep 10 2008, 05:44 PM)
[right][snapback]189451[/snapback][/right]
No big deal to convince them to make the change?
campoly
post Sep 11 2008, 06:12 AM
Post #13
They changed it without hesitation although I think it was partially my fault that it fell off. I think it was weakened while driving through water that was building up on the street during a heavy rain. It was flimsy to begin with though.
This post has been edited by campoly: Sep 11 2008, 06:19 AM
texas-azera
post Sep 23 2008, 07:02 AM
Post #14
They changed it out without any argument. Thanks for the guidance and support. Feeling better about my car again.
Qman
post Sep 23 2008, 05:31 PM
Post #15
Drives: 07' Azera
It got mine too $1900. Curb with metal spike/rebarb sticking out cracked the low vailence and then pushed the power steering cooler back against the A/C core. A/C core had a hole in it. Watch out for those curbs.
No New Posts The Genesis Alternative... For Less
21 07 Santa Fe 1,191 Yesterday, 08:57 PM
Last post by: 8sonny
No new Topic has attachmentsThe Effects Of Going 100+ Mph In A Sonata
"There has been a fatality. The guy is in half"
102 alex2006sonata 1,378 28th November 2008 - 11:18 PM
Last post by: hugamuto
No New Posts The Multifunction Car Dvd Player Cdp0005
0 timusacs 13 28th November 2008 - 12:02 AM
Last post by: timusacs
No New Posts The Horn..
and no.. not how it sounds... hehe
5 Pinto_Siftbean 91 27th November 2008 - 09:47 PM
Last post by: david-paul-1
No New Posts Front Washer Pump Where Is It?
front washer pump not working
2 volrider 17 22nd November 2008 - 10:35 AM
Last post by: volrider
2nd December 2008 - 12:38 PM
