 Hyundai-Forums.com > Hyundai Models > Trajet Forum > Replacement Remotes
 Replacement Remotes
mickey taker
post Feb 6 2008, 10:17 AM
Drives: 2001 Hyundai Trajet 2.7 V6 quadcam
Status: OFFLINE
does anyone know how much a replacement remote for the central locking costs ,
for ages mine would unlock the car but not lock it , I changed the battery about 3 weeks ago and after a bit of fiddling with the little terminals inside I got it to lock and unlock ,
yesterday it decided it wasn't going to do anything and know amount of connection bending would make it change its mind
User is offlineProfile CardPM
QuoteReply
Hyundaiownersclub
post Feb 8 2008, 04:08 PM
Drives: Tucson
Status: OFFLINE
Not sure how much they are but are usaully only available from Hyundai
QuoteReply
montego
post Feb 8 2008, 04:33 PM
GLOBAL MODERATOR
Group Icon
Group Icon
Group: Super Mod
Drives: XG's (2001&2002)
Status: OFFLINE
l have seen them on e-bay from time to time but if you do manage to get one you will need to get it programmed at your dealer
QuoteReply
Hyundaiownersclub
post Feb 9 2008, 04:32 PM
Drives: Tucson
Status: OFFLINE
Monty
Only on the later ones(2003 onwards I think ). Most earlier Hyundai's had an ETAC's unit which when you flicked a switch on the side you can program them. Even the Xg's have them.
QuoteReply
shayagalpert
post Mar 26 2008, 04:59 AM
Drives: Trajet
Status: OFFLINE
Sorry for my complete ignorance.
Hyundaiownersclub..... What is an ETAC unit and where can I find it.
QuoteReply
Hyundaiownersclub
post Mar 26 2008, 02:47 PM
Drives: Tucson
Status: OFFLINE
Its a black box underneath the fascia area by the fuse box. It basically the control unit for the alarm system. It has a switch on the side to enable remote programming on earlier Trajet's
QuoteReply
gnash
post Mar 29 2008, 06:00 AM
Drives: 2000 Hyundai Trajet 2.0 GSI
Status: OFFLINE
Hi,
I've found the ETAC unit on my 2000 Trajet 2.0 GSI but the sticker that tells you if the switch is OFF or SET is missing. The 2 remotes that came with the car seem to work (the red LED comes on when you press the button) but they don't open the car.
I've I tried the following to set up the remote:
1 - put the switch on the ETAC to SET
2 - pressed the large button on the remote
3 - put the switch back to OFF
4 - got out of the car and tried the remote to lock the car - but it didn't work :(
As I said I don't know which switch position is which but i tried both ways. I also tried with both remotes.
Am I doing it right? Do I need to have the key in the ignition or anything? How do I tell which switch position is which?
Help!
austin.
QuoteReply
shayagalpert
post Mar 30 2008, 04:15 PM
Drives: Trajet
Status: OFFLINE
Hi
Firstly thanks to Hyundaiownersclub for your help i mange to get my remotes working.
Gnash.... here is what you ned to do.
On my Hyundai the set position is closest the engine. So push the switch towards the engine. Next you need to lock and unlock each remote. So if you are trying to program two remotes you need to press the lock button on each one then the unlock button on each one. Then push the switch back towards the back of the car.
Hope this helps.
QuoteReply
shayagalpert
post Mar 30 2008, 04:19 PM
Drives: Trajet
Status: OFFLINE
Just realised my post is slightly unclear. Here is a step by step....
1. Push switch to set
2. Press lock on remote number 1
3. Press lock on remote number 2
4. Press unlock on remote number 1
5. Press unlock on remote number 2
6. Push switch to Off.
QuoteReply
gnash
post Mar 31 2008, 01:37 PM
Status: OFFLINE
Hi Shayagalpert,
Thanks for your help - all very clear. I tried it but unfortunately it didn't work, I also tried it with just one remote. Perhaps there's a fault with the unit in the car. I'll keep trying though.. :unsure:
Cheers,
austin
QuoteReply
cactuscake
post Apr 4 2008, 01:50 PM
Post #11
Drives: 2001 Hyundai Accent CDX 1.5
Status: OFFLINE
Austin,
I've just repaired my keyfob (it would unlock, but not lock the car since I bought it 2nd hand) and am wondering if you are experiencing a similar problem - can you feel the buttons click under your thumb when you press them? If not, it might be all gunked up like mine was...
Here's what I did to fix it:
Split the key as if to replace battery.
Pull on the rubber seal to remove the circuit board from the plastic case.
Push the circuit board out from the rubber cover and turn it over.
The two buttons have lock and unlock written beside them, slide a thin piece of metal (a flathead screwdriver will do) between the button and the board and twist, there's a tiny latch try not to break it.
The piece that comes up is in two sections, pop the circle through the bottom of the square section and clean any residue out from where they contact inside.
Replace the circular piece into the square, relatch it onto the board and test the button, it should click.
Reassemble the whole key.
You might have to go through setting the ETAC unit as well if this is not the original key.
Good luck!
QuoteReply
montego
post Apr 4 2008, 02:42 PM
Post #12
GLOBAL MODERATOR
Group Icon
Group Icon
Group: Super Mod
Status: OFFLINE
good first post from cactuscake :clap:
welcome to the forums :00000732:
QuoteReply
Taxi Shaun
post May 31 2008, 07:40 AM
Post #13
Drives: Hyundai Trajet
Status: OFFLINE
Thanks Shayagalpert,
I've just purchased (on ebay) a replacement remote for a total of £11.00 (including P&P).
I've followed your instructions and the new remote works fine.
Total time take, about 5 mins, and most of that time was locating the black box.
My car is a 2002 2.0gsi trajet.
Thanks very much for the posting, very helpful.
Shaun
QuoteReply
> Link To Us
> Similar Threads
Pcv Valve Replacement In 2005 Tuscon?
Forum : Tucson Forum
broberts20 590 3 Today, 02:46 PM
By: dries.cronje@bethalmail.co
Windshield Replacement: Oem Or Generic?
Forum : Azera Forum
nw07heavy 496 10 Today, 06:41 AM
By: andyman32
Brake Pad Replacement
Forum : 2G (1996-2000) Elantra & Lantra
lifelikechild 67 2 Yesterday, 09:34 PM
By: 248sonata
License Bulb Replacement
Forum : 4G (2006+) Sonata
frozentax 68 3 Yesterday, 09:33 AM
By: Sonata06GLSV6
Fuel Tank Air Filter Replacement
ElkScout 112 6 Sep 4 2008, 04:24 PM
By: MiamiLX
6th September 2008 - 09:49 PM
