> Will A 2000 And Newer Head Fit On 95 -99 Dohc
lance2008
post Feb 5 2008, 09:54 PM
Drives: 1997 Hyundai Accent
Hi i need to know if the engine head of a 2000 and later hyundai accent will fit on a 97 DOHC block. i noticed the newer hyundai accents all have DOHC engines, i have not came across a SOHC. But anyhow i looked at a DOHC head from a 2001 and it looks to be the same, all that was diffrent was the intake manifold but it bolts up just like the 97 manifold i have . the engines in 2000 and up are 1.6L engines and the 95-99 are mostly 1.5L so i have a 1.5L DOHC block and was just wondering if i could use the head of a 2000 or later, i can also come across 2000 and later alot easier to. any help would be greatly appeciated. :)
reggofcal
post Feb 5 2008, 11:32 PM
Drives: 1999 hyundai accent 1.5L,2001 hyundai accent 1.6L
I THINK IT WOULD WORK BUT IM NOT SAYING FOR SURE.AS LONG AS IT BOLTS UP THE SAME,IS THE SAME LITERS,SAME DOHC.I SAY TRY IT
byronguidry3732
post Feb 6 2008, 01:13 PM
Group Icon
Group: Super Mod
:00000732: lance!
See:
http://en.wikipedia.org/wiki/Hyundai_Alpha_engine
Just to clarify, do you have the G4EK engine block? Go check your engine identification number and reply back. The G4EK has a 75.5 mm bore and 83.5 stroke.
You want to install the cylinder head for the G4ED Alpha 1.6 liter engine. The G4ED has a 76.5 bore and 87 mm stroke.
Are you going to bore out the engine block to 76.5mm and replace the pistons? If you want the full 1.6 liter displacement, you will also have to replace the crankshaft to get the 87mm stroke.
Might as well swap out the entire 1.6 liter engine.
Byron
montego
post Feb 6 2008, 02:28 PM
GLOBAL MODERATOR
Group Icon
Group: Super Mod
Drives: XG's (2001&2002)
agree with byron, it would be far easier just to change the whole engine, tryingto do it your way will cause you a load of agravation
lance2008
post Feb 6 2008, 07:34 PM
i see good point guys, now will the 1.6L engine bolt up to the transmission that the 1.5 had? ( even if the 1.6 could drop in; my old intake would have to bolt up to the head beacuse of the type of ECU in the car. Its not equip with the extra sensor pickup's that the newer models have on the intake to run properly.)
Bryon, I Have the G4EK DOHC block
byronguidry3732
post Feb 7 2008, 04:57 PM
Group Icon
Group: Super Mod
lance,
One of our members, Rogerholdorf in Norway, is looking for a 1.6 liter DOHC cylinder head that he and I are going to modify. Do you have a lead on where to find a 1.6 liter DOHC head?
Back to your question. Will a G4ED engine block bolt to the transmission designed to mate to a G4EK block? I went searching for a diagram of the bolt pattern when I realized you did not say if you have the manual or the automatic.Let's assume that you have the manual, as do like 70% of Accent sold.
Here is the bolt pattern for the 97 Accent manual. Note the spacing and number of bolts holes in the bell housing cover
Here is the bolt pattern for the 2000 Accent manual.
Looks like the same bolt pattern by number and spacing.
Byron
Attached File(s)
Attached File  1997_Accent_Manual_Transmission_X43_014A.gif ( 51.11K ) Number of downloads: 39
Attached File  2000_Accent_1.6L_Manual_Transmission_emda011a.gif ( 52.7K ) Number of downloads: 33
lance2008
post Feb 8 2008, 05:51 PM
right now im actually coming by the 2000 heads from the junk yards there more common.
thanks bryon for the diagrams
i think ill just stick with getting a head for the 1.5 its to much to worry about switching it to the 1.6 enignes because of engine mounts electrical hook up ect. but i appreciate the info very much :)
No New Posts Will Coupe Wheels Fit A Lantra
Wheel fitment
1 EdGasket 17 30th November 2008 - 05:19 PM
Last post by: marek46
No New Posts 2000 Lantra Electrical..
4 cokaznrebel 28 30th November 2008 - 03:03 AM
Last post by: cokaznrebel
No New Posts Only 2 Spark Plugs In 2002-05 Sonata?
6 Bakesalee 63 26th November 2008 - 02:30 PM
Last post by: byronguidry3732
No New Posts Topic has attachmentsHeadlights Near Complete, What Do You Think?
11 liquid_02 164 22nd November 2008 - 10:04 PM
Last post by: Projekt_Accent
No New Posts 2000 Tiburon Trouble Code
1 Tiburonjoe 9 19th November 2008 - 11:16 PM
2nd December 2008 - 02:35 PM
