There SHOULD be build-in cables for rear speakers (as there are already cables connected to the cd/tape connectors in the dashboard). However having spent half a day, I could not find the connectors nearby the rear speakers bay. Therefore I apply extra cables for the speakers. Run the cables inside the plastic cover beneath rear door and then front door. The screws (and the board under back seat) have to be removed first. Apart from that, I would recommend you to add subwoofers if you expect better music quality. Not much can be expected from 5 inch rear speakers unless you're a news listerner (like me myself - most of the time). Hope this helps. Happy installing ....
Joko
