 Hyundai-Forums.com > Hyundai Models > Entourage Forum
> Entourage 2007: Front Suspension Grinding Noise, grinding noise from drivers...on turns
rv12
post Jan 31 2008, 01:39 AM
Drives: 2007 Hyundai Entourage 3.8
I have Hyundai Entourage, when taking right turns that are slightly elevated for e.g. driving into my drive way, I get grinding/clunky noise from the front on the driver side. It is like dragging metal shovel on side walk/
I took it to the dealer, initially they suspected strut on the passenger side and replaced it but the noise was still there...then they replaced tie end joint...and then finally after getting some tech help from Hyundai techline they replaced the sway bar and some bushes, then they replaced driver side strut the problem is persistant and easily reproducible...
I am not sure what else is left to be checked or changed in the front suspension
...it has been with the dealer most of the time after I bought it...I am really being patient all these days but I am getting disappointed now...
The dealer is very receptive and trying his best but looks like it is going no where except me revolving around the dealership..
could any one please help..
byronguidry3732
post Jan 31 2008, 10:29 AM
Group Icon
Group: Super Mod
Drives: 2009 Kia Sorrento 3.3, 2008 Sonata 2.4, 2003 Tiburon GT 2.7, 2004 Santa FE FWD 2.7
rv12,
Moved your post to the Entourage section.
Byron
rv12
post Jan 31 2008, 12:12 PM
Thanks for moving it Byron.
timk22
post Feb 1 2008, 04:58 PM
Drives: 2008 Hyundai Sonata SE V6 / 08 Elantra SE / 07 Entourage Limited
Sounds like it might be the driver's side outer CV joint - hasn't the dealer checked the axle assy by now?
Does it occur when making all right hand turns or just when making a slightly elevated turn?
This post has been edited by timk22: Feb 1 2008, 04:59 PM
rv12
post Feb 1 2008, 09:21 PM
Hi TimK,
Thank you very much for the reply! After much investigation by the dealership, it turned out that one of the bush on the driver side subframe/cradle(beneath engine) was slightly loose. They could find this out by using jakie and trying to raise each corner ..they found one to be having slightly loose they greased and secured the bush...and all the grinding noise disappeared :))
It was a great releif!!
---Thanks again
677222549
post Mar 28 2008, 08:56 PM
Drives: 07 Entourage GLS Leather
I have had a similar experience except it was diagnosed on the first visit. Apparently there is a bad batch of frame bushings out there on Entourage, Tuscon and Santa Fe's.
My two front bushings had self destructed and the two rear about to fall out as well (about 8000 kms on the odo). All replaced under warranty however I had also noticed excessive tire wear which Hyundai wouldn't address as I was told to speak with the tire manufacturer directly. (very non helpful)
In the end I was able to get the tires replaced under warranty after convincing them that the bushing problem (being part of the suspension) had caused excessive wear on the tires. So if anyone is noticing unusual tire wear this problem may be the cause and if so you should fight to have the tires replaced under warranty since the wear is a symptom of a failed Hyundai warrantied part. This saved me from buying a new set and I am now experiencing normal wear to date.
whiterabbit
post Apr 25 2008, 08:08 AM
Drives: trajet gsi 2ltr auto
I have the very same problem but on the Trajet in the uk , I have had 2 new struts in less than 3 yrs and its only got 21,500 miles.
Iam taking it back into the dealers to try and sort it out ,also just found out by the RAC who came to check the car , that the 2 rear brake pads havent been chaged since the day i took it from the show room .
bad hyundai dealer , bad boy .
Andrew
tylerpd1
post Dec 3 2008, 08:05 AM
Drives: 2007 Entourage
I have this exact same problem with my '07 Entourage. The dealer won't schedule me in for another three weeks, and I am afraid to drive it too much. How much of a safety concern is this?
No new Topic has attachments2007 & 2008 Rear Brake Problem ?
39 jayess 2,744 Today, 10:07 PM
Last post by: Dennis the Mennis
No New Posts Front "bumper" Question
6 Mainstreet Marshall 136 Today, 07:52 PM
Last post by: Don67
No new Topic has attachments2007 Sf Brake Problems
106 BDinNWO 5,369 Today, 01:06 PM
Last post by: Don67
No New Posts Front Rotor/pad Replacement
0 Big B 71 14th March 2010 - 05:25 PM
Last post by: Big B
No New Posts Front Collision
11 Jonathan82 248 13th March 2010 - 10:39 PM
Last post by: Jonathan82
18th March 2010 - 11:48 PM
Privacy Statement
