Dear Mason,
Recognize that this is an 8-year old Tiburon. From the information given, it is not possible to diagnose one cause. Here is a list of several:
1) E10 Tailamp Relay (under the engine compartment relay box) could be stuck or sticking 2) Multifunction Switch (on the turn signal stalk) could be worn out. Forum member have reported this wearing out and needing replaced. 3) M28 Stop Lamp Switch (located under the dashboard behind the brake lever) is stuck, cracked housing, failed return spring.
Check all of these, stop lamp switch first.
Byron
