right then, if the engine revs. o/k but the car will not 'pull' when cold it would, as l said in my p.m. indicate a gearbox problem. this could be down to the input/output speed sensors but could also be something more serious, it would be worthwhile changing the fluid (SP111) this may help. it would also be sensible to get the gearbox electrics checked out on the scanner at your dealer. one more thing that may be worth a try is to disconnect the battery ground lead for a few mins. doing this will reset the computer
