Hey there, I just joined the forum the other day and mentioned that i've been having major problems with my engine....i shal explain....
It started off with a check engine light appearing about a year ago but the car has been running fine up untill about 4 months ago when i noticed that the idle had become very rough and acceleration was deteriorating. under heavy accelaration the engine started to develop a small missfire however under normal circumstances the car ran absolutely fine. Then within the last two months it suffered from a severe loss of power and wont rev above 4000rpm. when im driving along i have to feather the throttle and can use about 10mm of travel only otherwise the engine chokes and revs drop untill it nearly stalls. This presents major problems when i encounter hills, the engine has no torque whatso-ever and on motorways i struggle - reli struggle - to reach 70mph unless im going down hill. If for example im accelerating and the revs hit 4000 rpm the check engine light starts to flash and the revs drop to 1500rpm + car almost stops and i cant use the throttle (is this limp mode kicking in??). This morning i went out to the car and when i started it it kept stalling for about 1/2 hour untill finally batt went dead. charged battery and finally got it started with help from a 4.5litre v8 and some jump leads (45 mins it took!) however now the car will not rev above 1200 rpm and check engine light has dissappeared. Someone please help im at a loose end!!! thanks simon
p.s. there is also a very annoying rattle that only occurs between 2500rpm and 3000rpm and seems to be eminating from dashboard. y only at certain rpm? is it something to do with a specific engine vibration at those rpm or it it because that is the cruising (therefore most used) rev range??
This post has been edited by Old Bert: Jan 22 2008, 09:01 AM
