That or a wiring problem that will cost 3 days at $100/hr for an auto mechanic to find.... New ECU is $1600...both options are very expensive...
This all started after Hyundai started looking at a problem with the vent doors some time ago but I couldn't prove a thing. They must have jarred some plug or connection because A/c started playing up after that !
Of course they don't want to know you after warrenty is over unless you pay through the nose and in the end they just outsource the problem plus their cut to an auto elect who will advise Hyundai what the problem is and hyundai will then decide the ECU needs replacing (it may be ok but they will replace it) or the car needs to be taken apart to find the wiring problem at my expense
No way am I changing the ECU unless other engine related problems are apparent. Hyundai noted that they had never ordered an ecu for a terracan since the car was introduced! so odds are the problem is wiring related.
This post has been edited by pickard: Jan 24 2008, 06:57 AM
