 Hyundai-Forums.com > Hyundai Models > Trajet Forum > Trajet Won't Start
 Trajet Won't Start
yogi3
post Jan 19 2008, 11:49 AM
Drives: trajet 2l gsi, 70000 miles
Status: OFFLINE
my trajet 2.0l gsi petrol won't start.
broke down whilst driving a couple of weeks ago, towed home, error codes suggested cam sensor error.
saved up for new sensor but still doesn't start. Had to recharge battery as it went flat.
Immobiliser symbol fashes 5 times when ignition turned on, is this faulty?
Plugs spark and are wet.
Any help appreciated.
:beer:
User is offlineProfile CardPM
QuoteReply
Hyundaiownersclub
post Jan 20 2008, 12:32 PM
Drives: Tucson
Status: OFFLINE
If your sparks are wet and are sparking then its not immobiliser. Can you do a compression check on it?.
QuoteReply
weeboab
post Jan 26 2008, 01:31 PM
Drives: trajet 20 crtd gsi
Status: OFFLINE
If plugs are wet and sparking it should start ??
Did you clear the fault codes after fitting sensor?
Does the cam sensor fault code still come up?
Did you check the cambelt, valve timing ?
as above have you done a compression test
QuoteReply
Hyundaiownersclub
post Jan 27 2008, 07:35 AM
Drives: Tucson
Status: OFFLINE
I have had two where the cambelt starts jumping teeth
QuoteReply
weeboab
post Jan 27 2008, 10:52 AM
Status: OFFLINE
Im thinking cambelt has gone causing sensor fault code :)
QuoteReply
Hyundaiownersclub
post Jan 27 2008, 01:34 PM
Drives: Tucson
Status: OFFLINE
If this is the case then it a fair bit of money to fix
QuoteReply
yogi3
post Jan 29 2008, 07:23 AM
Status: OFFLINE
cambelt is intact, cleared codes.
cars now in local garage after the aa tried to start the car which resulted in a backfire blowing off oil cap and destroying a plug.
expensive repair coming i think.
QuoteReply
Hyundaiownersclub
post Jan 29 2008, 11:42 AM
Drives: Tucson
Status: OFFLINE
So they tried easy start in it then?.
QuoteReply
yogi3
post Feb 7 2008, 06:16 PM
Status: OFFLINE
engine dropped 3 valves, trashing head and 1 piston. If anyone knows where i can get a engine from, central scotland, i'd appreciate it, thanks.
QuoteReply
weeboab
post Feb 7 2008, 11:35 PM
Status: OFFLINE
Have PM'd you as not sure if posting details breaches forum rules :thumbsup:
This post has been edited by weeboab: Feb 7 2008, 11:37 PM
QuoteReply
Sparks
post Feb 26 2008, 02:01 PM
Post #11
Drives: Hyundai trajet 2.0 CRDI
Status: OFFLINE
QUOTE(yogi3 @ Feb 8 2008, 01:16 AM)
Had similar problem. Heard noise like a bearing of the generator had failed. While driving to the garage engine stopped. Towed to garage. Diagnosis was that bearing from cam belt spanner was totally broken causing the cam belt to slip over the gearwheels. Much, much mechanical damage.
Overhauled replacement engine not available and would cost an awful lot of money nayway. Ended up with an extensive engine overhaul and an outrageous invoice.
QuoteReply
myttentwitten
post May 21 2008, 02:28 PM
Post #12
Drives: 2002 Hyundai Trajet, Diesel 2.0, Automatic
Status: OFFLINE
Same problem?
We have 2002 Trajet 2.0l Diesel Automatic and currently have similar problem. Driving car one day and it stopped, immobilised, and would not start again. After waiting a while was able to start it and drive home.
Booked in with dealer (meanwhile problem became more and more frequent) who did 60,000 mile service, and scanned computer and told us the cam belt sensor was the problem, and that there was no engine problem.
Took it away while we waited for the part and had no problems at all after the service. However after taking it in for the sensor to be replaced the problem has returned.
The dealer has had it for two days since then and have no idea what the problem is.
The cam belt was replaced only a few months ago, so this was not done at the 60,000 service.
When the car stops randomly like this the engine light comes on. However it is only on sometimes when the engine is actually going.
So we've just paid nearly £500 for the service, and another £200 for the cam belt sensor (which obviously wasn't required) and the car is still unusable!
Any other suggestions would be gratefully received.
This post has been edited by myttentwitten: May 21 2008, 02:48 PM
QuoteReply
Hyundaiownersclub
post May 23 2008, 12:33 PM
Post #13
Drives: Tucson
Status: OFFLINE
Do you mean camshaft sensor. If you do then the associated wiring can be a problem to the ecu. It can also be the cambelt out of sync. Have they checked the injectors for leak off or fuel rail pressure. I dont like to slag off dealers but are they checking it properly.
This post has been edited by Hyundaiownersclub: May 24 2008, 06:34 AM
QuoteReply
> Link To Us
> Similar Threads
Sunroof Won't Slide All The Way Open?
Forum : Veracruz Forum
hoo320 29 0 Oct 10 2008, 09:36 PM
By: hoo320
Remapping Of Trajet 2litre Diesel Engine Ecu
Forum : Trajet Forum
olderbutnotwiser 269 13 Oct 10 2008, 12:53 AM
By: trajetXG
Trajet Owners Manual
mazen 21,118 299 Oct 8 2008, 07:47 AM
By: labejof
Recommended Tyres For Trajet
TRAJET1715 338 16 Oct 8 2008, 07:06 AM
By: TRAJET1715
Trajet 1st Service
Mrrrjez 199 5 Oct 8 2008, 05:21 AM
By: BlackDugong
13th October 2008 - 05:44 AM
