 Hyundai-Forums.com > Hyundai Models > Tiburon Forum > GK Tiburon (2003-2008) > Wierd Transmission Activity
 Wierd Transmission Activity, automatic
Crick3t
post Dec 21 2007, 01:28 PM
Drives: 2003 Hyundai Tiburon GTV6
Status: OFFLINE
I have an automatic 03 GTV6 with about 83,000 miles. Recently, I noticed that when I am at a stop light, holding my breaks, I feel my car lurch, like it's trying to shift into gear.
Also, this morning, I was at a stop sign, and when I released the break and pressed the gas, it revved up as though it were in neutral for about half a second, and then kicked into gear, causing me to peel out.
There was a cop behind me and I received an "exhibition of speed" ticket for losing traction with the ground. WTF!?
Anyway, I tried to explain what happened but the dude gave me a ticket anyway. Before I can contest this ticket to get it changed to a "fix-it-ticket" I feel like I should accurately diagnose the problem.
This behavior seems to occur mostly when the car is still cold in the mornings. Another item that might factor into this is that I got my transmission fluid flushed and replaced about 1,200 miles ago, but this problem didn't start until about 400 miles ago.
Anyway, I hope somebody can give me a little insight into this. Short of changing my oil and fixing electronic problems, I'm not very automobile savvy.
User is offlineProfile CardPM
QuoteReply
montego
post Dec 21 2007, 03:33 PM
GLOBAL MODERATOR
Group Icon
Group Icon
Group: Super Mod
Drives: XG's (2001&2002)
Status: OFFLINE
first question, when you had your trans. flushed did they use the genuine SP111 fluid?
QuoteReply
byronguidry3732
post Dec 21 2007, 05:18 PM
Group Icon
Group Icon
Group: Super Mod
Status: OFFLINE
Dear Crick3t,
I have no experience with A/T problems on the Tiburon, BUT this sounds very similar to an A/T problem in a 2001 Sonata I own. The Sonata engine is a 2.4 liter, and I am not sure if the transmission is the same or not.
I was getting the same symptoms:
a) acted like it was in neutral on start
B) lurching on the 2nd to 3rd gear shift
c) acting like the transmission fluid level was low but was not
The dealer replaced the input and outoput sensors and this did not fix the problem. Eventually, the dealer replaced the throttle position sensor (TPS) and everything is fixed.
Did you get a Check Engine Light? The TPS can be tested before replacing, as it costs about $148 for the part.
Byron
QuoteReply
Pelican
post Dec 21 2007, 05:55 PM
Expert
Drives: 2001 Subaru Outback & 2006 Azera Premium
Status: OFFLINE
QUOTE(Crick3t @ Dec 21 2007, 02:28 PM)
If the fluid changed wasn't SPIII that would explain the behaviour.
It takes a few mile for damage to occur, yours started at about 800 miles after the flush. Were did you get your flush/fluid change done?
This post has been edited by Pelican: Dec 21 2007, 05:56 PM
QuoteReply
Crick3t
post Dec 21 2007, 06:19 PM
Status: OFFLINE
Bryon, no check engine light.
And Pelican, it was at a "Cheveron Oil Stop" I will inquire with them about what fluid they used and post.
QuoteReply
scat1234
post Jan 25 2008, 12:47 PM
Drives: tiburon
Status: OFFLINE
Hi, i have that same symptom on shifts from 2nd to 3rd gear, it bucks hard over 3,000 rpms,
i just had a fuel pump replaced, where is the TPS located and how much does it cost to fix?
Any help you can provide i would appreciate, i have an '03 Tiburon GT.
QuoteReply
byronguidry3732
post Jan 28 2008, 02:45 PM
Group Icon
Group Icon
Group: Super Mod
Status: OFFLINE
Dear scat,
The TPS is mounted on the throttle body as shown:
Byron
QuoteReply
mara
post Mar 4 2008, 07:05 PM
Drives: 2007 Hyundai Tiburon GT V6
Status: OFFLINE
i have an automatic 07 GT v6 and it does the same thing.. if im going uphill it seems like its stalling the entire time whether im using the regular automatic or the shiftronic, and it does the same if i try to accelerate quickly.. its brand new and it only has 7000 miles and it kinda worries me.. i havent gotten an oil change in a while but the light hasnt gone on yet.. could that be part of the problem?
QuoteReply
Crick3t
post Mar 7 2008, 01:18 PM
Status: OFFLINE
warranty!!! You're still under warranty. Take it back to the dealer and tell them what's going on.
QuoteReply
Crick3t
post Mar 16 2008, 03:17 AM
Status: OFFLINE
I read in another thread here that you can re-set the ECU. Is there a chance that that would solve my problem?
QuoteReply
Crick3t
post Mar 28 2008, 01:46 PM
Post #11
Status: OFFLINE
Well I feel stupid now. I went back to the Chevron Oil Stop for another oil change, and they checked the level of my transmission fluid and couldn't get any reading. I told them about the problems I have been having and that they started about 1500 miles after they had changed my transmission fluid. They told me that I should have brought it in sooner because they have a 30 day warranty on their work.
They filled my transmission fluid for free though, and the problem has gone away. I have been monitoring it for the last 48 hours and it doesn't seem to be leaking. My only idea is that maybe they didn't fill it up all the way the first time. I just hope there wasn't any damage done by driving around for so long with little or no transmission fluid.
::kicking myself for not checking for the obvious::
QuoteReply
ElonCooper
post Apr 1 2008, 12:24 PM
Post #12
Drives: 2006 Hyundai Sonata LX
Status: OFFLINE
Get the shop to verify the problem with the fluid level, and confirm they had to add fluid. Take that to court with you regarding the ticket, to get that thrown out.
QuoteReply
nsgtr88
post May 24 2008, 11:26 AM
Post #13
Drives: 2004 Hyundai Tiburon GT 2.7
Status: OFFLINE
Im having problems going into 3rd gear. It has a bucking feel to it. As if the whole trans is jumping....Could it be the TPS, or do I need to flash the ecu?
QuoteReply
> Link To Us
> Similar Threads
2002 Santa Fe Transmission Leak At Cooling Line
DetJoeF 33 0 Oct 10 2008, 09:08 PM
By: DetJoeF
Transmission Drain & Fill
Forum : 4G (2006+) Sonata
John_ 236 12 Oct 10 2008, 06:52 AM
By: Sequoiasoon
Transmission Problem
Forum : 1G-3G (1989-2005) Sonata
jaek707 72 3 Oct 8 2008, 04:18 PM
By: theiceage05
Transmission
duggar62 73 0 Oct 7 2008, 03:54 PM
By: duggar62
Transmission Flushing Diy
theiceage05 390 19 Oct 4 2008, 08:35 AM
By: npolite
13th October 2008 - 07:03 PM
