The lighting of BOTH 4wd lamps at the same time indicates a problem with the E11/E12 Vacuum Solenoid ccts . I suggest you UNPLUG and REPLUG the connectors. They are the two solenoids Adjacent to the ABS module. On switching on the ignition the ECU and other computers do POST's (PowerOnSelfTest"s) and part of that is to check the 4WD solenoids for continuity. (dont ask how, I dont know ) Cheers WVICK
Edit: it requires a POR (PowerOnReset, Ignition switch off/on ) to immediately reset the fault condition. 4Wd can not be selected, while this fault condition is present. I have the feeling that if the ECU no longer sees the "original" fault after a while it will remove the check status and consider the fault condition fixed, hence normal operation resumes.
This post has been edited by Wvick: Dec 15 2007, 07:59 AM
